Author: Subject: MegaBlade battery not holding charge
MegaBladeMatt
posted on 14/3/15 at 04:05 PM Reply With Quote
After fitting a new battery, one run out in the car and the battery is flat again.
It seems a good chance the rectifier/regulator could be the fault, I will be checking the alternator tomorrow using a multi metre.
Has anyone ordered a direct fit replacement with extra cooling fins? I have read that some of the uprated ones need modification which I would rather avoid if possible.
The below thread recommends using a CB250 super dream item which seems cheaper than the other item listed below, any suggestions on which I should go for?
Not worried about the price difference just want something that should hopefully last.
http://www.locostbuilders.co.uk/viewthread.php?tid=161626
http://www.ebay.co.uk/itm/200844852458?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
http://www.ebay.co.uk/itm/190710245411?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Matt
[Edited on 14/3/15 by MegaBladeMatt]
bigfoot4616
posted on 14/3/15 at 05:44 PM Reply With Quote
im fairly certain the one i had fitted when i had a blade engine was the super dream one. dont know how old it was but it had bits missing from a couple of the fins and was still working fine when i swapped to a R1 engine 4 years after getting the car.
i'm guessing it was a genuine one so i have know idea on the quality of aftermarket ones.
MegaBladeMatt
posted on 14/3/15 at 05:46 PM Reply With Quote
There are some original ones on ebay, I am trying to find a wiring diagram as think the super dream ones may need a 12v feed.
http://www.ebay.co.uk/itm/271442690030?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
bigfoot4616
posted on 14/3/15 at 06:38 PM Reply With Quote
its 6 years since i rewired the car originally so cant remember how mine was wired, i think the green wire just joined one of the others, either the red or black.
very vague memory's so not much help to you really.
MegaBladeMatt
posted on 14/3/15 at 06:46 PM Reply With Quote
Thanks anyway, hopefully someone with more recent experience can shed some light on it.
Mole-UK
posted on 15/3/15 at 12:38 PM Reply With Quote
I'm looking into changing the rectifier on my blade engined car as I think it may be breaking down... voltages upto around 15.4v, but I believe the battery is also well on its way so I plan to just overhaul the lot.
I've just found this on here which shows which wires are which on the superdream rectifier...
bigfoot4616
posted on 15/3/15 at 11:17 PM Reply With Quote
as the green appears to be an earth must of been the black and red that where joined on mine.
MegaBladeMatt
posted on 16/3/15 at 07:44 PM Reply With Quote
This is my rectifier currently, the engine was installed at AB performance so assuming this is what they fit. It is under the passenger side dash on a large ali plate.
guessing when rewiring the two outputs on a new rectifier will be one for red and one for green.
[img][/img]
MegaBladeMatt
posted on 17/3/15 at 08:29 PM Reply With Quote
The new rectifier I have just has two outputs, am I ok to just connect both reds in the above photo to the positive output and both green wires to the negative/earth output??
MegaBladeMatt
posted on 28/3/15 at 03:30 PM Reply With Quote
After fitting a new R1 rectifier, Gutted to find I am still only getting 12v at the battery.
Any advice on how to check my stator?
Thanks,
Matt
Mole-UK
posted on 28/3/15 at 05:57 PM Reply With Quote
Using a multimeter on the resistance setting, test across each of the 3 wires as shown on this picture:
They should all be around the same resistance.
Then check between each wire from the stator and earth, all readings should be open circuit/infinite resistance, if any of the readings whilst testing to earth are low, then the stator has started to short out.
MegaBladeMatt
posted on 28/3/15 at 06:46 PM Reply With Quote
Thanks for the info mate I will try this out tomorrow!
MegaBladeMatt
posted on 17/4/15 at 07:52 AM Reply With Quote
Just to update this thread, in the hope it may help anyone with simialr issues in the future.
After chnaging the rectifier and still having the issue, I ran a new live from the rectfier to the battery and now charging perfectly.
Seems there is a fault in the old live wire somewhere.
Easy fix shame I didn't try that first!
Thanks for all the help.
Matt
posted on 17/4/15 at 09:56 AM Reply With Quote
Matt
Doh!!! How many time have I thought that, So many blind alleys too little time !
