<<  1    2  >>
Author: Subject: flatshifter setup kent
kentmagpie
posted on 23/3/15 at 10:14 PM Reply With Quote
Hi guys,
I've contacted flatshifter direct with the question but wondered if any of you guys knew of a decent workshop in Kent that could setup my flatshifter max 100% correct?
daniel mason
posted on 23/3/15 at 10:32 PM Reply With Quote
What are you having trouble with!
kentmagpie
posted on 23/3/15 at 10:40 PM Reply With Quote
Hitting false neutrals on up shifts. I've gone through the instructions again and again to double check everything is set up correctly and it seems to be. I even went to the point of starting over and re setting it back up again after stripping everything off. I've tweeked about with the actuator position as that has made the most difference but still not perfect. Graham at flatshifter said to me nearly 100% of the time if it isn't working correctly it's because it's not been set up right. Or something is worn. Dammed if I can see it. I've not got the confidence to push my car as I'm worried I'm gonna be high revving through the gears when it inevitably finds a false neutral and pops my engine
daniel mason
posted on 23/3/15 at 11:09 PM Reply With Quote
The actuator needs to use its full travel to work correctly. Disconnect it from the gear selector and see how far the selector travels to make a full shift at the point you've connected the actuator too! You need to lengthen the selector arm to move the pivot point and re connect it to the actuator in a place where the selector moves the exact same distance as the actuator travel,
So you need to get the acuator, push the rod back towards the actuator body,then extend it to full travel and measure the distance. Mark the half way point and that's where it needs mounting!
[Edited on 23/3/15 by daniel mason]
kentmagpie
posted on 24/3/15 at 08:11 AM Reply With Quote
I've done this already but whether I've done it correctly is another thing. My gear selector has exactly an inch travel at the point that it connects to the actuator. It's as near to 90° as possible and in a straight upright position (not pivoting at an angle) where it meets the actuator. So at this point I connected my actuator with the clamp loose, marked the halfway point between stroke lengths and connected it in dead centre.
It was terrible in this position and really struggled to upshift at all. I've been moving the actuator in the clamp fractional amounts upwards and have it much better but still way to many false neutrals. That's why I want a fresh set of eyes on it just in case I'm losing the plot and missed something obvious (which is highly possible)
Autoflock Motorsport
posted on 26/3/15 at 04:09 PM Reply With Quote
I have the same issue,
the amount of travel needs to be 25mm.
I did a fair bit of research on the bike forums, the main cause of false neutrals is poor gear selection ie weak foot or bad shift movement on the selector. This shows that the main cause is the actuator postition. Other than that I fear the cause may be internal to the box. I have also read people saying the clutch can be altered to repvent this although ive not read too much into it.
This is a good thread so im keeping an eye on this :-)
Kind regards
Raj
http://www.locostbuilders.co.uk/forum/23/viewthread.php?tid=183445
posted on 26/3/15 at 04:10 PM Reply With Quote
might be worth posting up some pictures here of your selector arrangement, I will do the same if you want as I have the same kit or at least one of grahams first kits
Kind regards
Raj
kentmagpie
posted on 21/4/15 at 07:12 AM Reply With Quote
Think I've finally sorted it. I phoned up Graham from flatshifter and after a brief chat he told me that the length of the gear selector rod (or from the mounting spindle to where you connect the actuator shaft) should be 110mm. Although it can be slightly different but this should be a minor amount of mm. When I measured mine it was 128mm effectively meaning that my actuator was struggling to select gears hence why I was hitting so many false neutrals. After some grinding and drilling I've managed to re pivot my mount and re connect the actuator at 110mm. What a difference it's made. I'm still fine tuning slightly and i've all but eliminated the false neutrals. Since I've moved it I've done nearly 100 miles and only hit 2. Before I was hitting them all the time. If anyone needs any info on it ill be glad to offer any help.
posted on 21/4/15 at 07:22 AM Reply With Quote
thats fantastic news mate!!!!!!!
Keep us posted with progress and how it behaves. Great result so far
Kind regards
Raj
kentmagpie
posted on 21/4/15 at 07:24 AM Reply With Quote
Did u get yours sorted?
posted on 21/4/15 at 07:37 AM Reply With Quote
not had chance to change anything as kept snapping drive flanges due to extreme camber caused by poor wishbone setup on the rear, on track next friday (hopefully) so will see then, I will check the rod length tonight though. Can you explain the exact dimensions mate ie fron the end of the actuator in stationary position to selector joint centre 110mm etc
just so I know exactly what to check tonight.
Kind regards
Raj
kentmagpie
posted on 21/4/15 at 07:52 AM Reply With Quote
Best thing to do is take off your gear selector rod and measure the length between the 2 attachment holes (gear spindle and actuator hole). My original length was 128mm meaning that my actuator couldn't travel further enough to engage gear. Graham was amazed it was working. It should be 110mm. I've since re drilled it and moved my actuator over to keep the 90° angle needed. Remember that the actuator and gear selector must be as close to a 90° angle as poss otherwise you'll lose efficiency. I'll try and take pics but it's hard to get the phone in the right area.
posted on 21/4/15 at 08:39 AM Reply With Quote
you have explained it very well pics would be great but not essential. Thanks a lot for your help, will report back with tonights results
Kind regards
Raj
posted on 22/4/15 at 07:11 AM Reply With Quote
measured my actuator rod last night and it is 88mm long
Kind regards
Raj
kentmagpie
posted on 22/4/15 at 07:31 AM Reply With Quote
Way to short. Your gonna need to lengthen that out to 110mm. A lovely headache for you
posted on 22/4/15 at 07:37 AM Reply With Quote
thing is I have the installation instructions and I cant find the 110mm anywhere, all it states is that it needs to be as close to 90 degrees as possible and have 25mm (1" of travel??
Kind regards
Raj
posted on 22/4/15 at 07:40 AM Reply With Quote
Kind regards
Raj
posted on 22/4/15 at 07:43 AM Reply With Quote
my setup
Kind regards
Raj
kentmagpie
posted on 22/4/15 at 08:27 AM Reply With Quote
my setup
Ring Graham at flatshifter and have a word. He basically told me that any more than a few mm in even direction on 110mm and it won't work properly. He's basically that if it was measured 100% correct that 25mm actuator travel would be achieved at a length of 110mm. Mine was 128mm and I would've told u that it looked like it travelled 25mm but it was probably travelling 27mm or summin around there. You'll probably find that your actuator is only travelling 22-23mm and it needs to travel the full 25mm for maximum efficiency. Double check with Graham though
posted on 22/4/15 at 09:37 AM Reply With Quote
i may have my wires crossed here, but the 110 dimension is the rod which comes out of the actuator? if it is does it not matter the lengt5h of this as the travel will always be the same?
Sorry if im having a blonde moment
Kind regards
Raj
daniel mason
posted on 22/4/15 at 11:08 AM Reply With Quote
That rod only travels around 25 mm each way so needs mounting dead center!
I think he's refering to the lever on your gear selector. So from centre of selector to the mounting home for your actuators rod end needs to be circa 110mm which should give you the required travel to make a shift. Sounds like his was 128 so the 25 mm travel on the actuator wasn't enough to make the shift as the lever was too long
kentmagpie
posted on 22/4/15 at 11:23 AM Reply With Quote
Yep on the money. It's the gear selector lever that has to be 110mm from mount to mount dead centre. My lever measured in at 128mm from hole to hole therefore my actuator rod couldn't travel far enough to engage gears properly. If yours is actually 88 then your rod isn't travelling far enough and using max efficiency.
grazo
posted on 22/4/15 at 11:50 AM Reply With Quote
Hi Guys,
Graham from Flatshifter, please call or email me if you are still not sure.
The reason the manual does not say measure down from the center of the gear selector shaft 110mm is that this method does not allow for gearbox play, the 25 mm in each direct is correct and very simple but hard to explain, so i have started saying to measure from the center of the gear selector shaft to the point you have connected the gearshift actuator and if that point is not very close to 110mm then you have made a mistake.
Above is a picture of the gear shift actuator incorrectly installed, why !! because they have just connected to the standard linkage which is far too short instead of extending it to the correct length ie about 110mm we say about 110mm as every gearbox is different and you must follow the directions below to get the exact position .
Hi ,
Some of the most common mistakes to definitely avoid that customers commonly make when installing the Flatshifter Max electric gear selector systems.
Any questions problems etc. please do not hesitate to call or email us. mailto:MAIL@FLATSHIFTER.COM 01206 322557
If you imagine you are connecting the Max actuator to your gear lever ( some people do) when you put it into gear the gear knob moves a lot further to put into gear that the bottom of the gear-lever, but at some point down the gear lever there is a point where the lever has moved exactly 25mm to be fully into gear that is where the actuator would connect to, the same applies to the drop link directly on the gear selector linkage, but often it will need extending. IT IS NOT THE LINKAGE THAT NEEDS TO BE 110MM LONG BUT THE DISTANCE BETWEEN THE CENTER OF THE GEAR SELECTOR SHAFT AND THE ACTUATOR Drop link MOUNTING POINT (which will be about 25mm of travel)
No 1
The Max electric gearshift system actuator has an effective stoke of 25mm (1”) in either direction, since the effort produced is progressive over the length of this travel it is very very important to utilise the full 25mm stroke. This will dictate the point along the length of the link from the gear selector shaft or gear-lever at which the actuator has to be connected. In most instances this will be at or towards the end of the lever.in this instance near enough is not good enough i.e. if the actuator is placed in the position where 23 mm of movement is used to put fully in gear the actuator will try to extend to 25 mm ie it is trying to damage something if it is was fitted say at 27 mm then the actuator will still only move 25 mm so it will not be fully into gear & you will get missed gears.
Please pay close attention to all angles and measurements in your installation manual and please remember NEAR ENOUGH IS NOT GOOD ENOUGH.Normally a measurement of approx 110mm is required from the center of the gear selector shaft to the position the actuator connects to the gear selector arm / drop link , often this will require the link to be extended if not the Max system will not work properly This LAST POINT IS VERY VERY IMPORTANT and is the most common mistake when installing the Max system.
No 2 Applies to both systems do good quality electrical connections and attach earth & live wire etc preferably back to your vehicle`s battery if possible.
No 3 Do not solidly mount the actuator use the swivel mounting supplied it needs to move to follow the arc of the gear selector arm etc..
No 4 If it does not work properly you have not fitted it properly.
No 5 Check the gear linkage for free play; this represents an effective loss of stroke. Tighten or replace any ball joints or other linkages as necessary
Check that you have the correct level of oil in your gearbox, if the oil level is low the gears will run hot after a short period and become tight.
Check that the clutch is clearing properly, any clutch drag will cause the gears to mesh and prevent you changing gear cleanly.
Check that the chain is in good condition and correctly adjusted with not to much slack.
Please pay close attention to all angles and measurements in your installation manual THEY ARE VERY IMPORTANT .
Any questions problems etc. please do not hesitate to call or email us. mailto:MAIL@FLATSHIFTER.COM 0044 1206 322557 OR 01206 322557
posted on 22/4/15 at 11:54 AM Reply With Quote
I under stand now pal, good info on this thread.
I though you meant the rod which comes out of the actuation, but you mean the rod which links the end of the actuator to the gear selector splied bolt.
I shall measure this tomorrow, also I know the travel of the actuator is actually slightly more than 25mm, so if you find it is changing down fine but sometimes struggles on the up shift it can be extended the correct way to allow a bit more travel.
Will measure the CORRECT part tonight lol
Kind regards
Raj
posted on 22/4/15 at 12:19 PM Reply With Quote
AS USUAL SUPERB CUSTOMER SERVICE FROM FLATSHIFTER!!!!
Thanks for you responce graham, the pic above is on my car, dont know if you remember but you did a minor repair and upgrade on my gear change ecu last year which is now working a treat, I didnt know that was the standard linkage and I havnt measured it yet but will do when I get back to the workshop after.
Also thank you very much for the information you emails, its much aprpeciated.
I will report back with the dimensions
Kind regards
Raj
<<  1    2  >>
