Author: Subject: ZX9R carbs
richard munnis
posted on 26/11/15 at 07:45 PM Reply With Quote
ZX9R carbs
Hi Folks
Do i need a vacuum take off on my inlet manifold to run my carbs ,running a pedal box so dont need vacuum for a servo thanks in advance Richard
Dingz
posted on 26/11/15 at 08:33 PM Reply With Quote
only if you want to use the vac advance on the dizzy.
went on and on.
mcerd1
posted on 27/11/15 at 11:55 AM Reply With Quote
As above you only need it to run a vac advance or a MAP sensor for the ignition
If you've not got a dizzy then it will be easier to use the TPS that comes on the carbs instead of a MAP sensor.
But if you want to run either a vac advance or a MAP sensor then you'll need a take off point on each branch of the manifold, then join these together in a small chamber and the run a line from this to the sensor / dizzy.
The evens out the pulses you get in the vac lines from the each cylinder which can upset ignition systems
If you do fit a take off on each cylinder they can also be used for balancing the carbs
[Edited on 27/11/2015 by mcerd1]
richard munnis
posted on 27/11/15 at 12:06 PM Reply With Quote
Carbs
richard munnis
posted on 27/11/15 at 12:07 PM Reply With Quote
Carbs
Thank you for info
Will be running a nodiz unit with TPS so was not sure
Cheers Richard
posted on 27/11/15 at 03:02 PM Reply With Quote
Just blank them off so you can use them for balancing.
