Author: Subject: WANTED - Bike conversion parts
TheHighlander123
posted on 17/9/16 at 07:18 AM Reply With Quote
Looking for the below for my Westfield SEIW - Putting a ZX9R engine into it.
Thought I would check for 2nd hand parts before buying new.
OR if anyone knows of a company that will supply the below
Engine cradle/mount kit
Prop adapter
Modified prop
Gear cable change and shifter kit
Baffles for my modified ZX9R short sump
Manifold (I already have my ZX9R manifold which i might modifiy)
Westfield SEIW 1700 Forged crossflow, twin 40s etc etc etc - Now about to do a ZX9R
TheHighlander123
posted on 20/9/16 at 07:24 AM Reply With Quote
Back to the top
TheHighlander123
posted on 1/10/16 at 10:06 AM Reply With Quote
I have the prop adapter now.
CosKev3
posted on 1/10/16 at 11:05 AM Reply With Quote
Because you are going to have to modify your chassis to fit the bike engine you can use a cradle off any manufacturer that offered a zx9 in a seven,so try Scottish kit car centre,MK etc if you want one ready made.
Can you weld?
If you can make your own custom cradle would be my advice.
TheHighlander123
posted on 1/10/16 at 07:50 PM Reply With Quote
Can you weld?
Yep I can weld to a reasonable standard.
I spotted a ZX9R cradle kit on the MK website so might just buy it and mod it to fit.
mark chandler
posted on 1/10/16 at 08:47 PM Reply With Quote
Sump baffle, just get a bit if Ali and cut to suit, have a Google for pictures, ultimately you need to punch a big hole for the filter, smaller fir the oil return and a few other near the middle.
Takes 20 minutes and costs a couple of ££
TheHighlander123
posted on 2/10/16 at 10:24 AM Reply With Quote
I found some plans for one online, one of customers has a punch and will do it for me
TheHighlander123
posted on 12/10/16 at 07:15 AM Reply With Quote
Right
I have got
Engine cradle
Prop adapter
Gear shift adapter
Now I require
Bike engine propshaft
Gear cable and shifter kit
CosKev3
posted on 12/10/16 at 08:22 AM Reply With Quote
Won't be much chance of getting a propshaft that will fit,as you are fitting a engine that was never fitted in a Westfield chassis.
You need to get a Sierra propshaft,get your engine fitted then measure up how long the prop needs to be and have the Sierra one converted by the likes of Bailey Morris.
Same with the gear cable really,get the engine mounted then work out where your cable needs to run and order it to length,the cable from MK in there gear kit is really long and I had to return it and get one the length I required.
TheHighlander123
posted on 12/10/16 at 08:56 AM Reply With Quote
Thanks Kev.
Was in at SKC at the weekend and they do an off the shelf prop for £280
http://www.kitcarparts-scotland.co.uk/propshaft-bike-engine/
So will probably do that once the engine is fitted.
Rosco86
posted on 12/10/16 at 12:53 PM Reply With Quote
you want a TRT prob really mate, its a tube in tube with rubber in between to soften the blows on your gearbox
My Build Thread
