Author: Subject: Shortened sierra handbrake spring
Matt21
posted on 30/10/16 at 02:10 PM Reply With Quote
Can anyone point me in the direction of a shortened sierra handbrake spring? Or can I bend and chop mine to work?
I'm getting some 13" TD's and see they foul in the handbrake mechanism.
I messaged a user on here who gad some made a while ago but no reply yet.
Instagram: @matt211988
Photobucket
My YouTube
Rosco86
posted on 31/10/16 at 08:18 AM Reply With Quote
RJK350 is who i got mine from last year, they have one less coil so it would be hard to alter the originals
My Build Thread
Smoking Frog
posted on 31/10/16 at 09:20 AM Reply With Quote
Try shortening your's, if it don't work then buy some. I was surprised how well it worked for me, but did take me about an hour a spring. Never used heat, just a good vice. Slip the spring over a solid bar (steering rack off-cut) while working on it so it don't get crushed. I also fabricated a bracket to support the handbrake cable away from the wheel. The handbrake calliper lever may also need work. Replaced nipples for shorter ones on front callipers.
Matt21
posted on 31/10/16 at 05:50 PM Reply With Quote
It was RJK350 I messaged
I just ordered a spare set so I'll have a go at modifying mine, hopefully it shouldn't be too tricky!
I have until May for the MOT anyway
Photobucket
My YouTube
CosKev3
posted on 31/10/16 at 06:05 PM Reply With Quote
I'm sure somebody on here put a pic up of there set up using a coil Spring on the cable,so then you can remove the Sierra one altogether
Matt21
posted on 2/11/16 at 08:42 AM Reply With Quote
Sorted!
Managed to man handle the original springs to remove a coil and reshaped it to how it should be, wasn't as difficult as I expected actually!
Photobucket
My YouTube
