OliilO
posted on 11/6/17 at 08:51 PM |
Small clearout
A few things that I don't need and need to get rid of to clear up some space. P&P in addition to prices shown at cost for your chosen
delivery method. Alternatively collection from Chatham.
Pair of Mac#1 top front wishbones, powder coated black. Use standard bushes and transit drag link but need an adjuster. Replaced with rose jointed
versions. £30
Sierra steering column. This has had the threaded section cut off and used a removable boss on the hexagonal section. Ideal for turning down and
having a weld on slug added. £35
300mm leather steering wheel. Unsure of make, I'll check. Used with the boss mentioned above (included if you want) but I don't know the
PCD of the 3 bolt pattern; I'll update when I've measured. Could obviously be re drilled as necessary. Price tbc on confirmation of
make.
Sierra stalks (indicators and washers) with 3-4" tails on the wiring. Never tested, so can't vouch for their serviceability but look ok.
£10
Heavy duty fuel filler pipe (this doesn't bend very much). ~1.75" internal diameter, 200mm long. £10
Flexible fuel filler pipe, from Car Builder Solutions. Approximately 560mm long, ~1.75" internal diameter. £10
nero1701
posted on 12/6/17 at 06:14 AM |
Steering column and stalks please.
OliilO
posted on 15/6/17 at 06:35 PM |
Sierra stalks now sold.
Open to offers on the other items.
