Author: Subject: Acewell speedo magnet orientation
craigdiver
posted on 6/1/18 at 09:51 AM Reply With Quote
Acewell dash speedo
I have a 7659 acewell dash and am currently building my drive shafts and have drilled a shallow 8mm hole to locate the magnet. Question is the magnet has a red line on one side and a blue spot on the other, which should face the sensor (and do I presume correctly that mounting the magnet on metal won’t affect its effectiveness?)
Craig
If it ain't broken, fix it anyway (just because).
Building - BMW powered Haynes Roadster/442E hybrid.
Volvo C30 T5 Polestar
russbost
posted on 6/1/18 at 10:08 AM Reply With Quote
They are usually mounted with the blue spot as the mounting face, but it actually makes no difference at all, it is a magnet & makes no difference which pole is facing the reed switch, it relies on magnetism not polarity of magnet. The essential thing is to ensure that whatever you are glueing it to is absolutely spotless, degrease with something like acetone, thinners or meths NOT something oily like petrol, paraffin or turps, attach with araldite, JB weld or similar
tims31
posted on 6/1/18 at 01:07 PM Reply With Quote
Mine never had any markings on but I mounted mine on the drive shaft can, filed the surface down slightly to key the surface and then surrounded it with Araldite leaving a small amount over the top just to hold secure.
Been on for 600 miles with no issues so far
Build: http://www.martinsfurybuild.co.uk/
craigdiver
posted on 6/1/18 at 01:28 PM Reply With Quote
great, thank you
snowy2
posted on 7/1/18 at 07:29 AM Reply With Quote
it is better to mount the magnets all the same polarity if you use more than one magnet.... if its only one magnet than it doesn't matter.
sometimes you are the pigeon, most of the time the statue.
