Author: Subject: Type 9 Gear Lever
Greenie
posted on 18/5/18 at 07:29 PM Reply With Quote
Type 9 Gear Lever
I am sure this has been asked before.
I need a gear stick for a type 9 that needs to reach under the dash section, can't fit an extension to the rear of tgebox due the rubber donut on the prop. Has anyone any ideas or has anyone got some images 3rd.
yamapinto
posted on 18/5/18 at 08:04 PM Reply With Quote
I have a custom made extension that bolts under the top tunnel rails and attaches to a shorthand gear leaver. It should clear a donut and still has the reverse gate
Greenie
posted on 18/5/18 at 08:32 PM Reply With Quote
Sounds ideal, have you any pics?
yamapinto
posted on 18/5/18 at 08:37 PM Reply With Quote
Not at the moment I made it quite a while ago and not seen it for a while since we went to the duratec if your interested I will dig it out and send pictures you will have to have some machining done to your existing gear leaver
Greenie
posted on 18/5/18 at 08:42 PM Reply With Quote
Definitely interested and would really appreciate it.
yamapinto
posted on 18/5/18 at 08:47 PM Reply With Quote
Just got it out but don't know how to attach a photo to a post
yamapinto
posted on 18/5/18 at 08:50 PM Reply With Quote
I have just put a photo of it in my photo archive if you want a look
[Edited on 18/5/18 by yamapinto]
tims31
posted on 19/5/18 at 08:03 AM Reply With Quote
Just copy the code at the top when you view the image in your archive and paste it in
[Edited on 19/5/18 by tims31]
Build: http://www.martinsfurybuild.co.uk/
Greenie
posted on 20/5/18 at 07:22 PM Reply With Quote
Cheers..... certainly given me some real direction....😁😁😁
MikeR
posted on 21/5/18 at 10:40 AM Reply With Quote
I think tiger had a budget / bodge solution I their Avon book. Prod me tonight and I'll see if i can find it.
posted on 21/5/18 at 04:10 PM Reply With Quote
Didn't have an extension on mine, but bent the standard Sierra gear leaver a little more rearward so it cleared the bottom edge of the dash.
MikeR
posted on 21/5/18 at 04:21 PM Reply With Quote
I really like that dash layout
Greenie
posted on 21/5/18 at 06:17 PM Reply With Quote
Here a quick prod MikeR
posted on 24/5/18 at 04:08 PM Reply With Quote
Thanks Mike - hand made out of plywood covered in black vinyl.
Bluemoon
posted on 25/5/18 at 09:46 PM Reply With Quote
Also like the Ali section to stop scuffing the chassis not seen that done before.
posted on 26/5/18 at 05:58 PM Reply With Quote
A case of adding it afterwards when I realised getting in/out was going to scuff that chassis rail. It worked well and was done from left over alloy trim strips I'd used on elsewhere on the car.
