Dick Axtell
posted on 20/7/18 at 02:13 PM |
Honda Generator Advice - No spark - Now Have Spark!
Hello LCB experts.
I have a Honda GX 160 5.5hp generator. Was using it to drill coupla holes, for raising the fuel tank. One hole successfully made, then the gen
coughed, and spluttered to a stop. It has never run since.
Here are the measures taken - so far:-
1: Suspecting a fuelling problem, I cleaned out the fuel tank and replaced the outlet/fuel filter and the fuel hose. Filled tank with fresh petrol.
Still no sign of starting.
2: Tried to give the carburettor a strip-clean, then decided to fit completely new carb. No start.
3: Checked the spark plug and discovered "no spark". After seeing YouTube clip about this, decided to replace the ignition coil.
4: New ignition coil fitted; still no spark. Bought new spark plug - still no spark.
So please can anybody suggest what could be wrong. Have run out of what other faults might have caused this non-function. You advice would be very
welcome.
Bear in mind that gen had been running OK initially.
TIA
[Edited on 20/7/18 by Dick Axtell]
[Edited on 21/7/18 by Dick Axtell]
jimmyd
posted on 20/7/18 at 02:54 PM |
Oil level ok? Mine has a cut out switch linked to the oil level.
Angel Acevedo
posted on 20/7/18 at 04:00 PM |
+ 1...
It may be marginally low and when pump picks up oil...
Dies immediately..
Dick Axtell
posted on 20/7/18 at 05:00 PM |
jimmyd & Angel, thanks for your suggestions. Will check this out tomorrow.
Dick Axtell
Bigheppy
posted on 20/7/18 at 05:51 PM |
Faulty stop switch. Wire to stop switch rubbed through and grounding out. Flywheel woodruf key stripped. Is the new coil fitted correctly I had a
small engine where the distance between the coil and stator was set with a piece of paper between the two. If it was any further away no spark. Did
the coil come with new plug lead if not check continuity/replace.
Just a few thoughts hope you get it sorted.
russbost
posted on 20/7/18 at 06:34 PM |
Not clear from your post, but I'm guessing this is magneto ignition? most small generators are. If so, how sure are you there's no spark,
spark generated from a magneto can be pretty invisible unless viewed in relatively dim lighting. If it has a spark, but won't run then I'd
suspect woodruff key as mentioned above as that effectively screws the timing up
If there is definitely no spark, & you've already replaced the coil & HT lead, then most likely the magneto is grounded either
thro' the stop wire/switch or elsewhere
Can you find a manual for it online, there is usually a "troubleshooter" - working thro' it in a methodical manner usually reaps
rewards, flitting from one guess to another like a butterfly on speed generally does not ................
Hope you get it sorted
Furore Formula Car - the only two seater modern Formula Car lookalike. I no longer run Furore Products or Furore Cars Ltd, but would still highly
recommend them for Acewell dashes, projector headlights, dominator headlights, indicators, mirrors etc, best prices in the UK! Take a look at
http://www.furoreproducts.co.uk/ or find more parts on Ebay, user names furoreltd & furoreproducts, discounts available for LCB users.
Dick Axtell
posted on 20/7/18 at 08:11 PM |
Bigheppy & russbost - Thanks for your additional thoughts on this very irritating problem. I'll check out the "kill" switch
connections and wiring tomorrow. (After checking the oil level).
Dick Axtell
posted on 21/7/18 at 12:19 PM |
Thanks again to All for your advice. Could see no spark, even in dark shadow conditions. So, in sheer desperation, I reassembled everything back
together, with the new parts, gave the starter cord a pull, and eventually it fired up !!
All I have to do now - reset the idle and load-running speeds. Back to YouTube again!
