<<  1    2  >>
New Topic New Reply
Author: Subject: Converting LiveAxle Westfield to Independant rear suspension
MikeR
posted on 23/4/05 at 01:36 PM Reply With Quote
aaah, but are we talking sprung or unsprung here?
Two of those joints are right next to the solidly mounted diff. most of there weight will be sprung. the two by the wheel - fair enough.
(or am i talking complete rubbish here?)
[Edited on 23/4/05 by MikeR]
gazza285
posted on 23/4/05 at 02:50 PM Reply With Quote
Two sprung, two unsprung.
MikeR
posted on 23/4/05 at 03:17 PM Reply With Quote
thats good enough for me, i'm right whoopee !
(welding fumes is my excuse before anyone wonders)
kb58
posted on 23/4/05 at 03:30 PM Reply With Quote
Originally posted by kb58
Originally posted by barraw
MikeR - to comment on the nose heavy design, I recently parked my car on a public weighbridge, and found the front to weigh 300kg and the rear 250kg - without me in it, but if you add 2/3 of my body weight to the front/rear ratio you get an almost perfect 50/50 split.
Did you try it or are you guessing? I ask because in a Seven the driver sits far to the back. I'd expect the driver's weight distribution to be more like 80% rear, 20% front. If you know where the CG of the car is you can calculate it, or just stay in the car on the weighbridge.
[Edited on 4/23/05 by kb58]
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
NS Dev
posted on 24/4/05 at 07:32 AM Reply With Quote
Originally posted by gazza285
The dedion tube itself is lighter than a live axle casing less diff (or should be if designed well) so that just leaves the diff
And not forgetting that you have to include the addition of four CV joints to the weight. I think that you would struggle to make a Dedion lighter than a live axle.
Ok..........I haven't done it so I don't know. I guess it depends on the axle used and the way the de-dion is engineered. If you used a Marina axle or an English with an alloy diff carrier then probably hard to beat weight wise with the dedion.
CV joints wise, the stock Ford ones can be lightened a lot (have a look at the GKN verisons, all machined away on the sides so you can see where the bolts run through) and the Ford driveshafts themselves are very heavy, I am getting some lightweight ones made as they need to be shorter anyway. (sounds frivelous for me but the lightweight ones are the same price anyway!)
Stu16v
posted on 24/4/05 at 08:20 PM Reply With Quote
thanks, that sounds like good advice. I will try softening the settings. I have SPAX dampers, but don't know the spring LB.
I will have a play and post a followup - once I get the car back on the road (as an alternator bracket bolt has snapped in the block so I have some drilling and tapping to do )
As a fellow owner of a live axled Westfield, the first (and probably best) thing you can do is get rid of the Spax IMHO. They just do not work with such a light car, especailly on the rear, no matter how soft you adjust them. A very popular replacement (and tried by myself) are to swap to Avo's.
Also, as has already been said, softer rear springs will help to. Some folk using their live axled cars for competition drop to as low as 100lbs, but remember that they are probably not *too* concerned about additional passenger weight...
To summerize, there is a lot you can do to improve things, at far less cost and hassle compared to changing the suspension type.
HTH Stu.
<<  1    2  >>
New Topic New Reply
