grusks
posted on 11/9/05 at 05:57 PM |
Zetec Clutch
Can anybody measure the clutch plate centre hole.
I have a mondeo drive plate (that whats ment to be in the box) but the input shaft in the type 9 is to big for the hole.
Is the mondeo and escort zetec clutch plate different sizes.
The input shaft is 25mm but the plate is 19mm for some reason.
I was wondering has the wrong plate been put in the box.
[Edited on 11/9/05 by grusks]
Need More Money
givemethebighammer
posted on 11/9/05 at 06:08 PM |
Something's not right. I have a 1.6 / 1.8 mondeo plate and cover (using escort 1.8 flywheel) with a 1.6 capri release bearing. The standard
sierra box fitted just fine. Either you have the wrong clutch components or the gearbox is not what you think it is.
QH codes:
Mondeo 1.8i 16v 10/96-00 Cover Eng Code :RKB
cc :1796
Eng Type DOHC
Spline Dims :220x26x23
Q10099
Mondeo 1.8i 16v 10/96-00 Kit Kit includes Concentric Slave Cylinder
Eng Code :RKB
cc :1796
Eng Type DOHC
QKT2164AF
Mondeo 1.8i 16v 10/96-00 Plate Eng Code :RKB
cc :1796
Eng Type DOHC
C1806AF
Mondeo 1.8i 16v 10/96-00 Kit 2 in 1 Clutch Kit comprising Clutch Cover and Clutch Plate
Eng Code :RKB
cc :1796
Eng Type DOHC
QKT1905AF
Release bearing
Capri 1.6 (23 spline) 8/72-84 Bearing Eng Code :LA,LCE
cc :1593
Eng Type OHC
Spline Dims :190x25x23
CCT133
Ford codes:
Ford cover 93BG7563AA (fits 1.8 flywheel),
Ford plate 93BG 7550AA
release bearing as above.
[Edited on 11/9/05 by givemethebighammer]
grusks
posted on 11/9/05 at 07:08 PM |
Ive checked my shaft (sound rude) and its 26x23.
So it looks like my drive plate is wrong (good old ebay)
Cheers Mr Hammer
Need More Money
big_wasa
posted on 11/9/05 at 08:32 PM |
The input shaft on a type 9 or an mt75 type box is 1" 23 splines.
The Zetec had 2 differant manual gearboxes you have the one from the lower power model.The higher power model had the mtx75 gearbox which also has the
1" 23 spline shaft.
I was lucky I picked up an escort 130 spec fly wheel which has a 240mm clutch plate with the 1" 23 splines.
All I needed was a standard clutch and a modded (westfield)release bearing for the mt75 box.
You should be able to use the clutch plate from the 2l dohc which has a 215mm plate with 1"23 spline..
Your standard plate is 220mm.
I think all the info is correct ,but I often am wrong.
regards warren
