Author: Subject: Alfa Engine + Box
Johnmor
posted on 6/2/06 at 11:37 AM Reply With Quote
Alfa Engine + Box
Getting there with assembly, hope it all works
[img][/img]
ditchlewis
posted on 6/2/06 at 11:51 AM Reply With Quote
have you used an adapter plate ??
if so where did you get it from??
ditch
Johnmor
posted on 6/2/06 at 11:56 AM Reply With Quote
Adapter plate
Yes, I used an adapter plate for a type 9.
Took the measurements, made a MDF template and then had an alloy one made.
So far so good, as i can use the original Hyd clutch.
ditchlewis
posted on 6/2/06 at 12:03 PM Reply With Quote
Cool
always loved the Alfa V6, it was just a shame they were always fitted to moving piles of Iron Oxide. but at least they were stylish piles of oxide.
Ditch
James
posted on 6/2/06 at 12:22 PM Reply With Quote
Looks lovely!
James
Bluemoon
posted on 6/2/06 at 12:38 PM Reply With Quote
Any pics/details of the sandwitch plate?? Wondered about doing the same. What cluch and release bearing are you using??
Humbug
Nice looking engine!
DaveFJ
posted on 6/2/06 at 01:09 PM Reply With Quote
Damn!! just had a little accident! need to change my pants now......
Dave
Johnmor
posted on 6/2/06 at 05:52 PM Reply With Quote
Bearing
The clutch release bearing, pressure plate and bellhousing came from an Alfa 164.
The bearing was sleeved to fit the shaft on the type 9 box, but it allows the hydraulics from the 164 to be used.I have tried it manually and it seems to work ok
I have used the friction plate from a Sierra, it is slightley smaller in diameter than the original Alfa but I hope it will hold up. The bellhousing was "trimmed" to remove the housing for the front diff.
There are some pics in my archive.
I have a second plate so i hope to transfer the dimensions to Cad but i'm not very familiar with CAD so I'll see.
If i scanned the plate into the PC would it provide an accurate image for use? Its pretty close to A4 size.
I should point out it has not been tested so fingers crossed.
Bluemoon
posted on 8/2/06 at 05:13 PM Reply With Quote
Thanks for the info. Just interasted as it is a possibility later down the line, I suspect others would also (scan would be fine, maybe with a ruler on there two, to give us an idea..)... How much smaller is the Serria friction plate?? I suspect you will get away with it if the is small change.
adz h
posted on 8/2/06 at 11:30 PM Reply With Quote
That looks like it will fit in a velocity, how many GG's does that kick out? All looks great.
Johnmor
posted on 10/2/06 at 07:00 PM Reply With Quote
The engine is an all alloy 12v 3.0l V6 output is about 190bhp (depending on model and age)
About 190lbs torque
It is a very free reving engine as it has a short stroke, will easy hit 6000 without complaint.
So should be fun.
