<<  1    2  >>
Author: Subject: 40...50...60..70..then slip and slide!??
Chaz
posted on 20/8/06 at 05:19 PM Reply With Quote
OK so i've just got my MK on the road and when i hit 60mph the car seems to steer itself left and right!!! Quite alarming!!! It gets even worse when i'm doing between 60-80mph and i let my foot off the accelerator pedal? What does all this mean?
I have never setup self centering and the steering wheel never wants to pull back to the center, is this my problem? If so what shall i do about it?
Smartripper
posted on 20/8/06 at 05:22 PM Reply With Quote
Hello,
I've gotten the same.
Now i got the rideheight set too 110 mm front and 140 mm rear and it's compleet over.
Also check front wheels 0.5 degrees toe out.
Daniel
posted on 20/8/06 at 05:24 PM Reply With Quote
sounds like a lack of self centering to me, my car does this too. Are you sure the top bones are on the right side to give suitable castor?
Mark Allanson
posted on 20/8/06 at 05:28 PM Reply With Quote
Originally posted by Smartripper
Hello,
Daniel
Toe out? is you car front wheel drive? I think the toe out is an SVA bodge, not intended for normal driving!
Chaz
posted on 20/8/06 at 05:33 PM Reply With Quote
I think the top wishbones are ok, with that little mushroom, thats all in the right place.
Shall i just adjust the steering rack so that the wheels toe in? Whats the deal with adjusting the suspension, how can that affect how your car handles in a straight line?
posted on 20/8/06 at 05:40 PM Reply With Quote
Originally I set my front wheels with 0 degrees toe-in (i.e. straight) and that was a bit twitchy at all speeds. Setting a little bit of toe-in settled things down a lot.
However, that was at almost any speed - if it's only going unstable at higher speeds then it sounds more fundamental (like aerodynamics). Might be worth playing with ride height, if that's worked for Daniel.
Smartripper
Hello,
I got the numbers from snoopy on the forum here,
The Indy just likes toe out,
Ride height is important look at other post here, it affects everything,
By greater speeds my car felt like riding on ice it was going from left to right all the time.
now with the ride height set and little toe out, it's like the car is on rails.
With toe in, the car just didn't drive that great as with toe out, but it's easy too try it out..
Also setting corner weight is important, but not so easy.
Daniel
nitram38
posted on 20/8/06 at 05:50 PM Reply With Quote
Proper castor angles will solve your problems. I am glad I took that advice on here. I remade my top bones to give adjustable castor and I am running 7 degrees (car is rear engined).
I can chuck it into roundabouts and know I am going to come out of the other side.
It is worth spending time getting this right.
Toe out is a bodge and I am pretty sure it is dangerous. After all the sevens made, you would think that this problem would be sorted by now!
Smartripper
posted on 20/8/06 at 06:00 PM Reply With Quote
Hello,
Toe out dangerous ???? explain please ??
http://www.locostbuilders.co.uk/viewthread.php?tid=43717
It's the post from snoopy, and it clearly says toe out 0-1 degrees.
I tried toe in from 0-1 degrees and it'was not so affective as 0,5 degrees toe out.
Drove the car on track also and it's great fun and like on rail also in the corners.
Daniel
posted on 20/8/06 at 06:05 PM Reply With Quote
I have the Des Hamill book on suspension - he states that anything between 1 degree toe-out and 2 or 3 degrees toe-in will work. With toe-out or straight-ahead it will be twitchy but will corner like it's on rails. With toe-in it will be more stable, but will not corner so well.
This matches my own experience.
Chaz
posted on 20/8/06 at 06:18 PM Reply With Quote
Ahh, that sounds more like it. I knew toe in couldnt be all that bad.
nitram38
Toe out might be ok for a circuit, but driving for a couple of hours on UK's roads will soon get to you. With toe in the car will be more stable at speed and predictable in corners.
The idea of toe in on rwd cars is that as the thrust comes from the rear of the car, it will force the front wheels outwards. Toe-in is there to compensate so that the front wheels effectively straighten up. Putting toe out in the fronts of rwd cars means that the toe-out increases under power and causes drag.
The effect is worn tyres.
But whether you have toe in or toe out, the problem of wandering is caused by lack of castor angle and even race cars have some.
Toe out is just an attempt to counteract the lack of castor in the book locost to give the feel of self centring and is a bodge.
The original post was not about race circuits or cornering, so my answer is related to the question.
[Edited on 20/8/2006 by nitram38]
TangoMan
posted on 20/8/06 at 06:25 PM Reply With Quote
The generally accepted practice for FWD is toe out and for RWD toe in. The reason behind this is the effect on teh suspension rubbers once driving. Front wheels on a RWD will be pushed so will strain teh rubbers backwards giving slightly more toe out (hnce the toe in start). The opposite will be true of FWD as the wheels are pulling the car along so will gain some toe in.
This is all well and good but the situation is more complex than that. The aim is to have the front wheels pionting in the correct direction on corners. Obviosuly the outer wheel needs a bigger radius of turn so teh wheel needs to turn less. Ackerman produced a method if achieving this and his system is widely used in Karting circles.
It may just be that the geometry on the MK prefers toe out to correct a situation.
Summer's here!!!!
nitram38
posted on 20/8/06 at 06:28 PM Reply With Quote
The "situation" is lack of castor
MK's solution was valve springs on the steering rack to help self centering instead of addressing the problem...........modifying the top wishbones.
Read the last line on this webpage regarding confusing ackerman with toe out: LINK
indykid
posted on 20/8/06 at 10:02 PM Reply With Quote
but my indy always self centered perfectly.
i got it set up by paul at plays kool when he was still doing bits with cars. it was set up with toe in, and handled supremely. afaics, the lack of self centring, while attributable to too little castor, can be sorted by setting up correctly.
the valve springs are a blatant bodge imo!
tom
nitram38
posted on 20/8/06 at 10:32 PM Reply With Quote
The other setting that will make your car wander is lack of toe in on the rears aswell!
I used to race hillman imps and I took the toe in out of the rear wheels. This made it slightly faster on the straights, but a bit twitchy.
Best to get your car 4 wheel tracked if you want to drive straight!!
I bought a 4 wheel tracking machine from ebay. It is old but it works!
ReMan
posted on 20/8/06 at 10:41 PM Reply With Quote
I'm in the process of setting my MK up as we speak.
The steering set up toe out was, I am sure, posted only for SVA purposes to get the thing to self centre, as was the valve spring bodge, as this would only work close to full lock anyway.
Mine starts to centre fine at this extreme anyway, but there is very little, read, none to speak of! at normal degrees of turning.
My front end was going very light at 60-70 , I raised the rear and dropped the front today and its made an immediate difference and feels planted up to top speed now.
I tend to agree that there could be more castor built in to the front end, but it's not just MK wishbones as i've got GTS adjustable top wishbones and I don't think they have any more..........?
Wether a heavier engine would help...
Bit slow but to add... I have seen mention before of rear wheel tracking. bt there is no adjustment on the Indy, only camber.
[Edited on 20/8/06 by ReMan]
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
nitram38
posted on 21/8/06 at 06:10 AM Reply With Quote
The castor problem is caused by too many "copies" of the 7 without any thought for improvement. After you got the first one "wrong", then you would think that after all these years, it would be put right.
All that has to be done, it modify the top wishbomes.
As soon as my car didn't self centre, I asked questions on here and as soon as I got the answer, I changed my top bones.
Why spend ages building a car that is not right?
I find the whole situation bizarre, in that we are still discussing this in the first place, because this should have been sorted years ago!
[Edited on 21/8/2006 by nitram38]
Syd Bridge
posted on 21/8/06 at 08:56 AM Reply With Quote
Too much negative camber on the fronts will make the car 'self steer' to the undulations in the road surface. As will insufficient castor.
Give it as much castor as possible, more than 5degrees certainly, and pull the negative camber back to less than 1/2 degree.
Particularly if you are running wide, flat, low profile tyres. But no-one does that surely, do they?
Syd.
nitram38
posted on 21/8/06 at 09:12 AM Reply With Quote
My car:
7 degrees castor
0.5 degrees negative camber fronts
0.25 degrees negative camber rears
1 degree toe in fronts (overall)
0.5 degrees toe in on rears (overall)
With the 4 wheel tracker, I also know that the wheels are correct in relation to each other i.e. the car does not crab.
paulbeyer
posted on 21/8/06 at 12:08 PM Reply With Quote
As far as I understood it the valve springs on the steering rack were not a bodge to resolve self centering but as a means to limit the amount the wheels could be turned left or right to overcome problems with the front brake flexi hoses coming in contact with suspension components on full lock - an SVA no no, but a totally different issue.
I could be wrong.
7 out of 10 people suffer with hemorrhoids. Does that mean the other 3 enjoy them?
nitram38
posted on 21/8/06 at 12:10 PM Reply With Quote
It is used soley as a self centre measure.
posted on 21/8/06 at 01:01 PM Reply With Quote
I am also surprised that manufacturers haven't sorted this yet (and it's not just MK). I was fortunate in that I had heard about this problem way back, before I'd made my top wishbones. I took advice, and modified their design so that I had a fair bit more castor angle - not difficult in the slightest, just a re-jig of the jig...
I have driven a car with insufficient castor and thus little self-centering - I prefer mine, as it is a much more pleasant sensation. It is possible to take my hands off the wheel and still go roughly straight ahead, but being so light it is still easy to turn.
There's no argument as far as I'm concerned - don't do a bodge to get through the SVA - fix the problem.
posted on 21/8/06 at 01:15 PM Reply With Quote
Is "the book" still printed with the incorrect upper wishbone geometry?
nitram38
posted on 21/8/06 at 01:24 PM Reply With Quote
As far as I am aware, the book is wrong.
<<  1    2  >>
