Author: Subject: gearbox mount
darrenga
posted on 19/9/06 at 12:11 PM Reply With Quote
gearbox mount
hi can anyone tell me if this is the right mount for 2.0 pinto type 9 gearbox,says it is for granada,but not sure if the are all the same Rescued attachment 31_1_sbol.jpg
posted on 19/9/06 at 12:23 PM Reply With Quote
Looks pretty much like the one I've got on my Mk 9 box.
Worth going to a scrappy to get the bell-shaped washer that fits underneath - stops the g'box flapping around so much.
posted on 19/9/06 at 12:27 PM Reply With Quote
or better still, get the Westfiled mount which is almost solid and only costs ~£9
James
posted on 19/9/06 at 02:30 PM Reply With Quote
Agreed!
I think it's a bit more than that but it comes with a set of bolts and is far less sloppy.
James
caber
posted on 19/9/06 at 05:06 PM Reply With Quote
The mount I got from Westfield recently looks exactly the same as above and did not come with any bolts!
Caber
John.Taylor
posted on 19/9/06 at 06:33 PM Reply With Quote
Mine came from westfield with bolts, but it's too narrow for the MK brackets and I couldn't be bothered playing with the old type 9 one so I bolted the new mount to a piece of metal which in turn bolts to the chassis. Not sure how good it all is as nothing is running yet!
whitestu
posted on 19/9/06 at 06:52 PM Reply With Quote
I have the sierra one, but don't see how the bell shaped washer makes any difference.
Stu
lexi
posted on 19/9/06 at 07:04 PM Reply With Quote
Caber
Check under some of your Landys and you`ll find bolts
Alex
