Author: Subject: Power File belts breaking
Ivan
posted on 19/10/06 at 03:39 PM Reply With Quote
I am getting tired (and poorer) because of my power file belts breaking at the glue line each time they get even mildly warm
Has anybody found an answer to this as the tool is useless at the moment because I just can't afford a new belt after every 3 or 4 minutes of use.
Otherwise its a brilliant tool - especialy for polishing work on the lathe.
By the way - has anybody found that grinding products to build a chassis cost almost what "the book" says the whole car will cost
RazMan
posted on 19/10/06 at 03:49 PM Reply With Quote
There are some variable quality belts on sale and the B&D ones are not the best around.
I have found that my belts tend to snap if I use the Powerfile in short bursts - long periods of operation are no problem.
Raz
PeterW
posted on 19/10/06 at 04:03 PM Reply With Quote
Take them back !
Not fit for purpose...! I don't know any of the sheds that would try and stand up to an argument about lack of quality if things are breaking after a few minutes.
I took back 4 Pirana jigsaw blades after I blunted the lot - cutting stainless steel admittedly...
Pete
posted on 19/10/06 at 04:56 PM Reply With Quote
Just FYI, if you value your lathe you won't put emery/carbide abrasives anywhere near it. A sure fire way of ruining the bed and slides.
DarrenW
posted on 19/10/06 at 05:11 PM Reply With Quote
Have you put the belts on the right way round. Important to orientate as per arrow on inside of belt. They snap anyway but last a bit longer.
Take unworn snapped belts back.
Ivan
posted on 19/10/06 at 08:28 PM Reply With Quote
Yes I have (put the belts the right way round) - after the first one snapped I made doubly sure of that - but yes it always pays to check so thanks.
Mr G
posted on 19/10/06 at 08:43 PM Reply With Quote
The only time mine snap is when i've caught something jagged which either rips the width of the band down or breaks it completely.
Yours are definately running true after fitment I take it?
G
flak monkey
posted on 19/10/06 at 08:45 PM Reply With Quote
We use them no end at work and the belts last for ages. We use them for deburring cast iron and steel components. Think we buy our belts from buckhickman: http://bhinone.farnell.com/
Search for 'linisher' Clicky
[Edited on 19/10/06 by flak monkey]
Sera
http://www.motosera.com
robinj66
posted on 19/10/06 at 10:33 PM Reply With Quote
you could try a seller called HALLMORK on Ebay. I've not had any trouble with the belts I bought back in 2004
