<<  1    2  >>
New Topic New Reply
Author: Subject: What mig welder?
speedyxjs
posted on 11/3/07 at 08:54 PM Reply With Quote
What mig welder?
Can anyone recomend a suitable MIG welder for the chassis? Preferably new and on a reasonable budget.
posted on 11/3/07 at 09:04 PM Reply With Quote
clark 135 or 150, my 135 lasted 3 years of use and might walk again if i ever fix it
speedyxjs
posted on 11/3/07 at 09:07 PM Reply With Quote
How much? (im not tight, just on a tight budget)
blakep82
posted on 11/3/07 at 09:12 PM Reply With Quote
there was a topic light this just the other day, as a result, I'm replcaing my no gas MIG with one of these from machine mart
good price, and recommended by others on this site yesterday
people, tell me if i'm aout to make a mistake buying this
________________________
posted on 11/3/07 at 09:21 PM Reply With Quote
Personally I'd say the highest power one you can afford......
Buying a series of increasingly more powerful welders doesn't make sense in the long-run....
posted on 11/3/07 at 09:23 PM Reply With Quote
the only thing i find really annoying with mine is the lack of current control - i have two switches, hi/low and 1/2. I really should find out what they do, as it stands, low1 is crap, hi2 blows fuses, so i use it on either hi1 or low2 and just change the wire feed to match. You just need to develop technique to work around the machine.
blakep82
posted on 11/3/07 at 09:25 PM Reply With Quote
http://www.locostbuilders.co.uk/viewthread.php?tid=62058
^ thats the topic i was talking about
speedyxjs
posted on 11/3/07 at 09:29 PM Reply With Quote
Iv just noticed in the new book, in the 'Welding Practices' section that, he recommends at least a 150 amp welder. Iv seen 90 amp welders that say they are capable of welding up to 4mm steel. Is 90 amp too weak? (sorry if im starting to sound a bit thick )
ps just noticed iv reached over 100 posts. Yay
blakep82
posted on 11/3/07 at 09:31 PM Reply With Quote
have a look through here
http://www.mig-welding.co.uk
got a calculator for working out the maximum thickness, many manufacturers over estimate the thickness
davie h
posted on 11/3/07 at 10:13 PM Reply With Quote
been reading this and the other thread and i have decided that the clarke 151te looks the best bet
zetec7
posted on 12/3/07 at 03:15 AM Reply With Quote
I've successfully welded 3/16" plate (which is what, 4.75mm?) with my old Calarke 100E Turbo welder many times, with complete penetration and no problems at all. Since I'm unlikely to have to weld anything much thicker than that, I don't need more power. Considering that the new Clarke 130EN has 30 more amps available than my old one, it should be able to do anything up to 1/4" plate. Do we NEED more than that?
http://www.freewebs.com/zetec7/
wilkingj
posted on 12/3/07 at 07:09 AM Reply With Quote
As bigger one as you can afford.
One good reason is the duty cycle at lower and mid range amps will be effectively higer / longer.
Welding at a machines Max current is probably only about 20% ie 2 mins welding time during a 10 minute period.
Not a lot of fun when you want to get the job done.
Investigate your local welding specialists, they may have second hand industrial welders, or bottom range industrial welder.
In hindsight I wish I had gone for something better than my Sip150amp job.
Its taken me a lot of time to get used to it.
The wire feed on the cheaper welders is taken from the main transformer, so you can wire speed fluctuations so the welding is not so constant. Good ones use a separate transformer for the wire feed motor, eliminating this problem.
Still I cant really moan at the Sip, its done a lot of work, and the welder is the most cost efficient tool I own. Its paid for itself over and over again.
Best Regards
Geoff
http://www.v8viento.co.uk
garage19
posted on 12/3/07 at 07:59 AM Reply With Quote
Heres a spanner in the works..... why not buy a tig welder and tig weld your chassis???
I know its slower but i don't know why more people don't tig up their chassis?
Danozeman
posted on 12/3/07 at 10:20 AM Reply With Quote
Iv got an SIP migmate 130 turbo. Its a good welder. Id buy the clark 151 if i was to buy another one.
As said get the most powerful one you can but not a cheap powerful one if that makes sense.
Dan
ned
posted on 12/3/07 at 10:40 AM Reply With Quote
I built mine with this:
http://www.locostbuilders.co.uk/upload/IMG_0795.jpg
cost just over £200 on a 10% day or whatever discount day they have.
From my experience cheaper models have inferior quality wire feeds that invariably need more fettling and produce more frustration.
Ned.
beware, I've got yellow skin
andyharding
posted on 12/3/07 at 12:17 PM Reply With Quote
I built my chassis with a Clarke 135. No problems with power or duty cycle. After the chassis was tacked I fully welded it in one go without taking a break and the welder coped just fine.
The Clarke 135 is the highest power they (MachineMart) recommed running from a 13A plug. I only have a 13A feed in the garage and couldn't have used the highest settings on the higher models without blowing things.
As it is all the lights in our street flicker when I'm welding at night.
ned
posted on 12/3/07 at 01:46 PM Reply With Quote
I have run my 160amp on full power from a 13amp socket, no light flicker in the house/garage or anything. It's on a properly rated domestic circuit breaker and that's never gone so imho it can't be drawing the suggested current anyway.
all imho.
Ned.
Alan B
posted on 12/3/07 at 02:00 PM Reply With Quote
<hand up at the back> I know, I know....
It's about twice as much to set up up for and takes about ten times more skill to learn.....
Agreed, that when learned it is a fine skill to have (that's why I'm learning right now) I'm sure that it will come easier to me, but it is definitely an order of magintude more difficult to learn.
davie h
posted on 12/3/07 at 02:52 PM Reply With Quote
just been to B&Q they have a cosmo mig welder gas or gassless 130 amps for £150 do you think this would be any good
iank
posted on 12/3/07 at 03:27 PM Reply With Quote
No, not really.
Do a search on 'cosmo' on the forum they don't have a reputation for reliability.
Anonymous
davie h
posted on 12/3/07 at 03:55 PM Reply With Quote
thanks for that i will stick with the clarke 151te plenty of folk have that one on here and have no complaints about it
Simon W
posted on 12/3/07 at 04:42 PM Reply With Quote
Ordered myself a Clarke 151te yesterday. I have never tried Mig welding before so will spend a few weeks blasting holes in scrap steel and then pluck up courage to start on the chassis One tip that I have PM'd to me a number of times, buy a decent auto darken helmet (throw away the free handheld jobbie) and use Argon/CO2 mix gas instead of just CO2.
[Edited on 12/3/07 by Simon W]
davie h
posted on 12/3/07 at 05:23 PM Reply With Quote
i can weld but i have only ever used larger migs so i dont know anything about diy sets i just dont want to buy one and its turns out to be as much use as a chocolate firegaurd
blakep82
posted on 12/3/07 at 06:45 PM Reply With Quote
I'm getting mine at the weekend, interestingly, Halfords seems to be selling the mini Argon cylinders cheaper than CO2, or co2/argon. cheaper than machine mart too. the little cylinders are enough for me
posted on 12/3/07 at 08:43 PM Reply With Quote
other drawback with tig is that its a two handed job (unless im mistaken), with a mig you can hold a piece in place and tack it one handed, saves a lot of time.
<<  1    2  >>
New Topic New Reply
