LoMoss
posted on 23/4/07 at 08:06 PM |
How to reset house alarm
Moved into my new house and there is no instructions for the alarm. There is no makers name on the control, just 9930. Is there away this can be reset
at the controller pcb?
Just ask if you need any more info.
Hall
SeaBass
posted on 23/4/07 at 08:13 PM |
Sounds like a Scantronic system.
Some info here...
http://www.scantronic.co.uk
[Edited on 23/4/07 by SeaBass]
lsdweb
posted on 23/4/07 at 08:26 PM |
Yeah. Sounds like a Scantronic number.
Have a look here for some instructions - can't see the 9930 but try a
number that's close!
Wyn
dave1888
posted on 23/4/07 at 08:43 PM |
9930 is the keypad number you most likely have a 9800+
try this link it has quite a few manuals on it. Any probs u2u me and i'll have a look in the car to see if i have got any info.
http://www.securitycentres.co.uk/support.html
skydivepaul
posted on 23/4/07 at 09:00 PM |
engineers code should br 0 7890, this will put the system into engineer mode.
type 99 and enter (tick symbol) to exit the system.
you might not be able to change the customer code though without resetting to factory default
the manual for the 601/602 ihas very similar instructions as for a 9800
to factory default the programming you have to fit the link marked reset on the main pcb and then power the unit up
remember to remove the link when done
cheers
Paul
http://www.smartideasuk.com
http://www.smartmapping.co.uk
HD CCTV
IP security systems
access control systems
chrisg
posted on 23/4/07 at 09:02 PM |
Buy a dog?
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
LoMoss
posted on 23/4/07 at 09:23 PM |
Getting there.
It now shows 'lid tamper. reset required. 9651' The engineers code does not seem to work.
Would get a dog if it could survive for 4 weeks.
davie h
posted on 24/4/07 at 06:50 AM |
Getting there.
sounds like you are going away if you give me your address i will come round n switch on the light,tv,radoi etc i promise everthing will be there
when you get back
