New Topic New Reply
Author: Subject: Corner Weighting set up £40..!!!
GeoffB
posted on 23/7/07 at 07:19 PM Reply With Quote
Would this work..?
http://uk.aldi.com/
[Edited on 23/7/07 by GeoffB]
RazMan
posted on 23/7/07 at 07:37 PM Reply With Quote
Well the link doesn't
Raz
posted on 23/7/07 at 07:42 PM Reply With Quote
comes up as http:// only
Catpuss
posted on 23/7/07 at 07:45 PM Reply With Quote
Dunno, do you mean the air con unit or the woman in the shower?
A you mean the sunday special on scales that can take 180kg?
mark chandler
posted on 23/7/07 at 07:53 PM Reply With Quote
I collared 4 x ordinary bathroom scales and did my bec, set them up to all read the same with 4 x 25litre drums of water piled on each in turn and zero'ed at 100kg.
Set some slabs out on my drive and leveled with sand underneath to a bubble in a tube.
Balanced away, even with £4.99 scales they recorded a 5kg difference between front and rear if I leaned forward in the car or sat back so yes they will work, with 180 kg load should even measure a CEC.
Those are +- 1kg so just get them level.
Regards Mark
[Edited on 23/7/07 by mark chandler]
RazMan
No wubbleyoos
http://www.aldi.co.uk/
They look a bit posh for the garage but at £9.99 thats a pretty good deal. Not for my lardy car though (825kg)
[Edited on 23-7-07 by RazMan]
Raz
caber
posted on 23/7/07 at 10:02 PM Reply With Quote
I don't think its those ones they need a tap when unloaded to get them going!
I think they had some old fashioned spring ones listed last week but none at my local store this weekend.
Caber
MikeR
posted on 23/7/07 at 11:18 PM Reply With Quote
donkeys years ago i bought 8 scales from ASDA for 2.99 each or something. Plan was to corner weigh the car when i completed it. At the current rate we'll have moved from kg to a new scale by the time i finish
mad-butcher
posted on 24/7/07 at 06:56 AM Reply With Quote
same here 8 sets from Tesco at 2.99 Rescued attachment corner weight setup.JPG
DarrenW
posted on 24/7/07 at 08:44 AM Reply With Quote
A guy in my town who runs rally cars offered to set mine up inc camber and toe in etc on his fancy gear for £100 cash which i thought was a good deal for a pro set up.
John Pye, Bishop Auckland.
procomp
posted on 24/7/07 at 10:33 AM Reply With Quote
Hi as above profesional corner weight setup should cost no more than £30 on it's own.
But obviously not the lowcost method just more accurate.
cheers matt
New Topic New Reply
