Author: Subject: Type 9 Speedo Sender
MKMike
posted on 24/5/08 at 12:53 AM Reply With Quote
I found a type 9 in a scrapyard, no idea what model it came from, it has what appears to be an electronic speedo sender in the location where the cable would normally go. The sender has 3 wires coming from it.
Does anyone know how to wire it or know what colour code on the wires is?
I'll be fitting an electronic speedo so I'd like to use it if possible.
jollygreengiant
posted on 24/5/08 at 07:39 AM Reply With Quote
I think you will find the answer here.
Linky to wiring eplanation
But also you will have three wires, IIRC, Black, Brown and Yellow.
Brown should be earth. Black should be +12v supply and the Yellow should be the signal wires to the speedo head.
[Edited on 24/5/08 by jollygreengiant]
posted on 24/5/08 at 08:49 AM Reply With Quote
If anyone has one of these speedo senders going spare then please let me know - I have a box with a big gap where the sender should go!
chris_smith
posted on 24/5/08 at 12:19 PM Reply With Quote
anyone got a pic of what your describing on the type 9 (so i know mine is still there)
jollygreengiant
posted on 24/5/08 at 03:17 PM Reply With Quote
Not the clearest of photo's but might give you the idea. Taken looking vertically down from the top, nearside of box just in front of gear lever.
electric speedo drive T9 insit
