MonkeyHunter
posted on 21/10/04 at 03:27 PM |
I cant open the chassis with running gear, it says its an unrecognised file?
blueshift
posted on 21/10/04 at 03:48 PM |
Oh, it works for me (obviously). can you open the chassis assembly? I wonder if your download was corrupted.. could try downloading again, if that
doesn't work, maybe reinstall solidworks?
MonkeyHunter
posted on 21/10/04 at 04:11 PM |
If its "chassis.SLDASM" then no i cant, i can see them both in the preview window though :/ i will try downloading and reinstaling, as
sometimes when i quit it crashes with an unhandled exception.
Scott.
derf
posted on 21/10/04 at 05:16 PM |
If some one can u2u me with the info on where to upload... I have a small library of parts I'd like to share too, some basic wheels, hyabusa
engine model, a basic rendering of a 13b (rotary engine), shocks, nuts, bolts, a few human figures, some gears (chain drives), and a bunch of
imcomplete (i got bored before finishing them) items.
I am using 2004.
Also people who are using the older versions of solidworks can probably find the newer version on p2p sites like kazaa, their older authentication
codes should work on the newer version (at least that's what Ive been told). Ive been told that at least the '03 works on the '05
version, not sure how far back it will work. There might also be SW crack programs available on p2p sites such as kazaa.
derf
posted on 21/10/04 at 05:22 PM |
It would also be nice to have a database of parts ex:
.....................Chasiss
...........Frame............. Suspension
Book............+4..... Front...Rear...Shocks
Then for each part
..........................Original
.....Modified by user A.......Mod by B
Mod by C.........Mod by D
..............Mod by E........Mod by F
Sorry about all the periods, Ive never been good at ascii.
I would like to see a directory where each part that is original, my 13b for example which is quite unrefined, gets updated where a user can download
the model, then upload it with changes, having let's say 3 versions of the finished engine, each one slighly more finished than the last.
[Edited on 21/10/04 by derf]
Alan B
posted on 21/10/04 at 07:45 PM |
quote: Originally posted by derf
....Sorry about all the periods, Ive never been good at ascii.....
Translation to UK english..
period = full stop
In case you guys didn't know..![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
Mark Allanson
posted on 21/10/04 at 08:08 PM |
Nothing to do with american food additives then?
mackie
posted on 22/10/04 at 08:45 AM |
I have simple Rover V8, bellhousing and LT77 models. I'll upload them later if I remember.
MonkeyHunter
posted on 22/10/04 at 10:01 AM |
well it looks like this might go somewhere useful I better get modeling then!
Bob C
posted on 22/10/04 at 10:20 AM |
I have some models based on mx5 running gear that I can stick on.
I've only modelled a rear quarter of the chassis so far so I'll build up a full chassis model & download that.
Bob C
blueshift
posted on 22/10/04 at 11:17 AM |
If anyone has models they'd like to contribute, you can email them to me and I'll bung them up on a little temporary webspace until
something cleverer is worked out.
MonkeyHunter
posted on 22/10/04 at 11:33 AM |
Thanks for that Blueshift. Much appreciated!
jcduroc
posted on 22/10/04 at 07:45 PM |
Assembly / Part files
Blueshift
I downloaded your .zip file and the extracted files look ok.
I'm totally "virgin" with Soliworks (I have 2003 ... not complete - no user manual).
How did you do the parts (tubes) and the assembly (chassis)? Parts first and then put together (how?)? or assembly first?
Can you give me some guidance? I might contribute a little if I manage to be able to work with the da.. thing.
BTW I have the correct dims for the balljoints.
JCM
MonkeyHunter
posted on 23/10/04 at 03:11 PM |
jcduroc your best bet is to work through the online tutorials...
blueshift
posted on 23/10/04 at 03:13 PM |
Uhm, do the solidworks tutorials first.
If others want to email me some things to contribute, jon at leetfighter dot com. I will put up a little blurb about how I made the chassis if I do a
little site for the files.
Basically though, the tubes are extruded squares, laid out with mates and using blind and extrude-to-surface, then fixed and the mates deleted (or it
got too unwieldy). I think all the mates are there to do an adjustable length engine bay though, should be possible to unsupress a lot of them and
float the front tubes and have a nice auto recalculating front end. A few red herring old mates in there though, so not super straightforward.
Dizzy_G
posted on 16/3/05 at 02:28 PM |
13B drawing
could i get a copy of the 13B model if possible. IS there a Turbo on it? If not any idea how much bigger it is with a turbo attached??
i need to figure out if a 13B T engine will fit into a Dax rush.
Bob C
posted on 16/3/05 at 04:28 PM |
I spent a while adding my rear suspension to this solidworks model.
OMG the wheels are sticking into the chassis WTF....??? Ahhh - it's a +4 wide model.
Doh!!! - I'll bring it down to book dims eventually......... when I figure out how!
cheers
Bob
Darin
posted on 8/11/05 at 03:59 AM |
Any chance of using your modelled hayabusa
I am using 2004.
![](/images//smilies/smile.gif)
jon_haggerty
posted on 8/11/05 at 03:38 PM |
Is solid works anything like solid edge which is what i use?
chrisf
posted on 8/11/05 at 03:52 PM |
They are similar. SolidEdge actually sells SolidWorks their engine. However, the user interface is much easier in SolidWorks. If you understand
SolidEdge, you'll have no trouble with SolidWorks.
--Chris
blueshift
posted on 8/11/05 at 08:00 PM |
Cor, this topic brings back memories.
I think I have redone the front suspension since.
paul the 6th
posted on 23/7/08 at 10:41 AM |
old old old old old old thread!
Only just signed upto this site a few days ago. I've finally got hold of solidworks 08 and was wondering how far everyone got with this parts
directory/database?
I had a quick look on solidworks' own website - they do have their own forums with a "Data Exchange" section which could be
something to do with swapping designs.
I don't know if it would be worth setting up a standalone "LocostDesigners.co.uk" forum with all solidworks parts/design discussion
etc?
Might be a bit extreme?
Just wondered
GoDesign.me.uk - Self Adhesive Vinyl Artwork, Wide Format Printed Artwork and Customised Heat
Pressed Clothing...
http://picasaweb.google.com/haynesroadster - Roadster Photo Build Log
hellbent345
posted on 14/8/08 at 12:28 PM |
old thread indeed but i for one am interested in getting it rolling again, i have haynes rear uprights and bearing mounts etc, could use some engine
drawings (pinto or 2l DOHC is what i really need- or zetec) if there are any solidworks people hanging around anymore!
Cobra289
posted on 14/8/08 at 09:41 PM |
Yes there are.
I have made the Sierra front upright from a drawing posted at the forum.
See if you like.
Regards,
Cobra289
![](/galpreviews/a791588-SIERRA_UPRIGHT_01.JPG) ![Rescued attachment SIERRA_UPRIGHT_01.JPG](/gallery/a791588-SIERRA_UPRIGHT_01.JPG) Rescued attachment SIERRA_UPRIGHT_01.JPG
hellbent345
posted on 16/8/08 at 07:22 PM |
how does that hub stay on? im interested to know so i can see if i can redesign for a rear steer system? i need to know how the stub axle passes
through the bearing and is held on? thanks
alan
