beaver34
posted on 13/11/10 at 10:50 AM |
dry sump tank location
where do most people fit the dry sump tanks, i struggling to get it in the engine bay wher i would like it, can it be mounted in the passenger
footwell would that be an issue for msa reg though not being behind firewall?
T66
posted on 13/11/10 at 12:36 PM |
I very much doubt the regs would let you keep a tank of hot oil in the passenger cab of the car, personally I wouldnt want it there anyway.
From previous reading I think its a no, but the piping can go through the cab, but must be covered over under a suitable shield.
daniel mason
posted on 13/11/10 at 02:00 PM |
some do put it in passenger footwell but i would not take that risk myself!
perksy
posted on 13/11/10 at 04:08 PM |
Not sure of your layout or how much room you have
But this is mine if it helps
beaver34
posted on 14/11/10 at 05:02 PM |
thanks was looking at putting mine there, or behind the rad infront of the engine how much oil does that hold? and what engnie is it carnt see from
the pic
thanks
perksy
posted on 14/11/10 at 08:27 PM |
Vauxhall XE engine
The Tank is from SBD http://www.sbdev.co.uk/Dry_Sump_Systems/Dry_Sump_Spares_Acc/Dry_Sump_Spares.htm
Holds about 5 litres iirc
Mounted to the chassis on some rubber sheet
Be aware though that if you go for a smallish tank like this it needs to be mounted as near to the engine as possible
beaver34
posted on 14/11/10 at 09:00 PM |
Thank you,
Is there anything inside that tank baffles or the like as some I have seen have, I'm having one custom made i think and will mount it behind the
steering rack infront of the engine, hopefully should help with cooling and the pipe length will be short
nz_climber
posted on 20/11/10 at 10:02 PM |
Mine is where the passenger footwell used to be, put the firewall behind the oil tank
My tank is a bit bigger than 5L, will hold about 10L, but will run with about 8L. Engine Toyota Beams 3sge
http://aarons7.wordpress.com
