<<  1    2  >>
Author: Subject: Pre IVA pics - Picture Heavy!!
tims31
posted on 16/7/14 at 06:25 AM Reply With Quote
Originally posted by neilp1
Guys I have my IVA next week so thought I post some pics up here to see if you can see anything I've missed.
Cheers in advance.
[Edited on 15/7/14 by neilp1]
Not sure what the locking wire is there for but that looks anti-locked to me and far too loose.
Build: http://www.martinsfurybuild.co.uk/
AvonJas
posted on 16/7/14 at 06:38 AM Reply With Quote
Looking good
Don't think you will get away with using tape on top ball joint nut , it can't be reused if adjustment needed.
The Black Flash
posted on 16/7/14 at 10:38 AM Reply With Quote
Side repeaters on front arches are fine, only tested with the wheels straight ahead - I have this in writing from VOSA policy department, and it was also confirmed with them by phone during my test. I think the manual even states it now.
Clip on harnesses are fine - well the manual doesn't specify, however it does now state that FIA approval is accepted which never used to be the case. Most FIA ones are clip on, mine are and passed without comment.
Agree that the spacers on the belt mounts don't look ideal, but not a lot he can do about that really.
Do you have lock nuts on the master cylinder shafts? Can't see from the pics, but it's a fail if you don't have them. Like these:
Looks a really tidy build BTW, you should be proud of that
And good luck!
neilp1
posted on 18/7/14 at 07:42 PM Reply With Quote
Guys thanks for all the advice. I'm going to re-do the lockwire on the bias bar. Locking nuts are fitted to the push rods.
gremlin1234
posted on 18/7/14 at 08:25 PM Reply With Quote
two more points, (unlikely but not quite to the letter of the test)
the manufacturers plate should have things like colour, completely separate from the compulsory information. **
and the carpet in the drivers footwell may need securing round the edges.
** I also noticed that the iva test manual, has an errant space in its vin on the manufacturers plate ;-)
ashg
posted on 18/7/14 at 09:11 PM Reply With Quote
noticed another thing the lock nut isn't supposed to lock against the outer part clevis like that as it will stop it moving back and forward naturally. even if you set it with a bit of a gap there is still a chance that the bar will rotate and the nut will get closer and closer to the clevis until it binds up on the outer part.
it should lock up against the inner pivot pin of the clevis like mine below.
sorry to say it and im not sure where you got your pedals from but it doesnt look like a lot of thought went into the design.
edit.
even on the rally design ones their locking nuts secure agaist the clevis inner pin not the outer part.
something like this from cbs would sort you out
[Edited on 18/7/2014 by ashg]
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
avagolen
posted on 20/7/14 at 06:57 PM Reply With Quote
Just had a look through your pictures.
I think you need to put some insulation on the wires to your master cylinders.
Double insulated and all that.
HTH
Len.
kj
posted on 29/7/14 at 02:23 PM Reply With Quote
Any news on the test
Think about it, think about it again and then do it.
neilp1
posted on 30/7/14 at 04:59 AM Reply With Quote
It Failed!!
Biggest issue was emissions considering I had it rolling roaded, so I need to trailer it back to Motoscope!!
Brake bias
handbrake - no rear travel and tester was not happy with my cable clamps although it is what Tiger supply - await answer from him on these
nsr brake flexi too close to drive shaft
an extra p clip required on rear brake pipe
fuel pressure regulator bracket loose (well moved within rivets
and tabs on front hubs to disks weren't all bent over although they were loctited.
I have completed most things now other than the front hubs and emissions. I have altered bias bar and just need to check it.
kj
posted on 30/7/14 at 05:21 AM Reply With Quote
Not to bad lets hope your on the road soon
adithorp
posted on 30/7/14 at 09:17 AM Reply With Quote
Not too bad.
What were your actual emmision readings?
http://jpsc.org.uk/forum/
CosKev3
posted on 30/7/14 at 09:36 AM Reply With Quote
Not bad
Out of interest which clamps did you use on handbrake cables, and where abouts are they on cables?
gremlin1234
posted on 30/7/14 at 10:01 AM Reply With Quote
you should be able to drive it to them, since its a garage for repair after it has failed a statutary test.
should also give a chance to bed the brakes in a bit too.
neilp1
posted on 30/7/14 at 10:19 AM Reply With Quote
Emissions were a mile out. I don't have the reading on me, but I'll try and post them later on.
clamps on hand brake are just rear of the handbrake it's self. I'll try and get a picture of it.
code:
you should be able to drive it to them, since its a garage for repair after it has failed a statutary test. should also give a chance to bed the brakes in a bit too.
The place is 60 miles away. Would I be okay driving it there??
<<  1    2  >>
