<<  15    16    17    18    19    20  >>
Author: Subject: Reliant Kitten Project
roadrunner
posted on 28/9/21 at 08:51 AM Reply With Quote
Come along nicely.
big_wasa
posted on 28/9/21 at 09:43 AM Reply With Quote
Very nice
John Bonnett
posted on 28/9/21 at 05:27 PM Reply With Quote
Originally posted by big_wasa
Very nice
Thank you, everyone.
I'd appreciate any help and advice you could give me on a power distribution unit for my car that won't cost an arm and a leg. I know very little about them but from what I understand they offer a significant advantage over conventional fuses and relays.
John Bonnett
posted on 14/10/22 at 10:46 AM Reply With Quote
It's been a while since the last offering so here is a pictorial record of the intervening progress and to where we are at present.
We'll start of with an artist's impression which is a computer generated render onto the body frame. This was done by a chap in Germany and it blew me away when I first saw it.
[Edited on 14/10/22 by John Bonnett]
John Bonnett
posted on 14/10/22 at 11:08 AM Reply With Quote
Every little section of bodywork is like a mini project in itself and each gives a lot of pleasure in the execution. The rear of the car is inspired by the DB5 and specifically the line of the rear quarter panels and the light configuration. For the first time, I have used a wire frame buck made from 6mm steel bar and it worked out nicely having some advantages over a plywood station buck.
The shape of the area around the rear lights is complex and needed a bit of head scratching to work out how to form it.
The plate to accommodate the lamps was made separately
And then edge welded in position
John Bonnett
posted on 14/10/22 at 11:36 AM Reply With Quote
This car is going to have modern refinements which I hope will improve the driving experience without detracting from the outward classic body style.
If the car was designed, and it really wasn't, it's more of a case of make it up as you go along, you could say that it all revolves around the windscreen from a MK4 Fiesta. This was the smallest, most easily available and cheap electrically heated screen that I could find. This together with the Fiesta heated rear screen are the first of the upgrades. You need to be able to see and although the car will have a conventional demister it won't be anything like as effective as an electrically heated screen.
I like air conditioning and decided on a unit from VintageAir in the States. I then discovered that Dakota Digital make an automatic climate control system, fully integrated and wired for direct connection to the VintageAir unit. VintageAir also offer and ABS plastic box which is what they call a mockup of the actual unit so that the mountings can be fitted without any risk of damaging the actual unit. It is also considerably lighter which is an advantage.
I went for their smallest system but it is still pretty big and so a bit of thought was needed to work out how to fit it and cover it in with the dashboard/console. In the event, the dashboard took three months of work.
Dashboard removed for covering
John Bonnett
posted on 14/10/22 at 11:49 AM Reply With Quote
The main bodywork as far as the B post and the roof is now complete with just the metal finishing left to do so a bit of a milestone.
Mr Whippy
posted on 14/10/22 at 11:53 AM Reply With Quote
Amazing. I'm sure you could run a business making custom dashboards for people and seems a shame to cover that tbh. Would look quite nice painted body colour imo and more in line with the retro look of the car. Chrome plate all the plastic parts, would look very fancy
John Bonnett
posted on 14/10/22 at 12:00 PM Reply With Quote
Ha ha, That dashboard really was very hard work and I'm not sure I'd want to do another one. I felt that it needed to be covered with a layer of foam underneath to add a degree of softness to it. I've farmed the job out to a professional trimmer because I'm really not good at upholstery and she is, very good.
swanny
posted on 14/10/22 at 02:47 PM Reply With Quote
saw excited to see an update on this.
The rear end has a whiff of gilbern genie about it. very nice
John Bonnett
posted on 14/10/22 at 03:10 PM Reply With Quote
Thank you.
I think there are flavours of several different marques in there including the Harrington Alpine and once the front is on maybe a few more.
John Bonnett
posted on 16/10/22 at 05:01 PM Reply With Quote
I've started metal finishing the weld between the roof and the door aperture and it's coming along quite nicely. As a break from the laborious work with a body file, I decided to drop the engine and box in. It proved to be a really easy job which I manged on my own and without any assistance. Next, throttle linkage went on followed by the bulkhead fitting for the heater/aircon pipes. On the other side, the clutch cable and exhaust went on.
John Bonnett
posted on 4/11/22 at 01:53 PM Reply With Quote
As with all these make it up as you go along projects there are set-backs as well as steps forward and since my last offering there's been a bit of both.
I made a schoolboy error when welding the outside panels to the roof and have ended up with an asymmetric profile which will need to be dealt with at some point but not now. Not a huge job to rectify but a bit of a pain because it could have been avoided.
I'm currently focussed on getting the engine running and in preparation, all the plumbing has to be done. I'm using PTFE lined stainless steel braided hose and AN fittings. Although not cheap and not essential, I bought the assembly tools which are proving an absolute boon. For the engine bay line I've used a nylon sheathed pipe which is less obtrusive that the stark braided stainless steel. The tube is still stainless steel braided but it is covered by the nylon outer which involves one extra process when fitting the unions but in my view, aesthetically quite pleasing and worth doing.
[Edited on 4/11/22 by John Bonnett]
John Bonnett
posted on 8/11/22 at 06:56 PM Reply With Quote
I've been working out the runs for the coolant pipes which has caused a bit of head scratching but we're getting there. It is quite a costly exercise but thanks to the extraordinary generosity of one of our forum members, not as expensive as it could have been. This really is a fantastic forum like no other when it comes to the depth of knowledge and help that everyone is pleased to give and this experience is no exception and is hugely appreciated. Thank you. I'm not going to mention your name but you know who you are and if there is ever anything I can do in return, please just ask.
So, here are a few photos showing the progress.
Oh, and the new radiator is fitted.
John Bonnett
posted on 12/11/22 at 09:02 AM Reply With Quote
The fuel lines are finished apart from one fitting that I'm waiting for. Incredibly, they fit where I intended them to in the profile of the transmission tunnel that I made a couple of years ago. It's very nice when a plan works out.
John Bonnett
posted on 20/11/22 at 04:35 PM Reply With Quote
Being lazy, I lobbed out on an expensive fuel filler arrangement that incorporates tank breather and the larger bore pipe that's stops blow back and the pump cutting out. Unfortunately the outlet angle was at too steep an angle for a decent lead in to the tank so that was a bit of a downer.
So while it grieved me to do it, I had to take the angle grinder with a cutting disc to it, modify the angle and weld it all up. It didn't look too bad when painted and there are no leaks
I wanted the filler to sit in a joddled recess rather than flat on a piece of sheet so it was time to dust off the old Rolastep which I notice are now hugely expensive. I don't remember paying much for it many years ago when I bought it so, my good fortune that I have now because I could never afford to buy one now that's for sure. It does a great job and comes into its own with this application.
I then made a hammerform to match the profile of the aperture and all turned out reasonably well.
https://i.ibb.co/3sB7RBh/IMG-4049-Small.jpg
John Bonnett
posted on 20/11/22 at 04:36 PM Reply With Quote
And two more photos that got left off
Quite and acceptable feed in now and will be even better when the filler pipe is shortened a tad.
[Edited on 20/11/22 by John Bonnett]
HowardB
posted on 21/11/22 at 05:06 PM Reply With Quote
that is looking amazing -
Howard
John Bonnett
posted on 21/11/22 at 05:38 PM Reply With Quote
That's really kind of you Howard, thank you.
It's been a bit of a struggle but the tank is now securely strapped down and the panel containing the fuel filler bonding in. I'll leave it clamped up for a day or two to give it a good chance to cure.
Mr Whippy
posted on 22/11/22 at 12:31 PM Reply With Quote
I like that, probably the safest location you could put the fuel tank and filler.
John Bonnett
posted on 22/11/22 at 01:02 PM Reply With Quote
Safety was one of the reasons for siting it there and the other is that just forward of the axle should give a better weight distribution. There should be just room for the spare in the space left.
John Bonnett
posted on 13/3/23 at 02:54 PM Reply With Quote
A bit more progress since my last update.
I managed to source from the States an adaptor to fit the aircon compressor with threaded union outlets which are in the ideal position for my setup.
I'm using an Odyssey Extreme battery which is standing on its end and have fabricated a battery box in stainless steel to suit.
and mounted in the car
The engine bay fuse/relay box is installed and the loom fed into the cabin.
The accelerator cable now attached to the pedal.
John Bonnett
posted on 19/3/23 at 03:31 PM Reply With Quote
I'd like to begin by a big thank you. I've been struggling to find the mating halves of the cooling fans and the aircon compressor and one of our members out of the goodness of his heart gave me what I've been looking for and posted them to me refusing any payment. I'm completely overwhelmed and very touched by such kindness and generosity which has warmed my heart.
Today has been a bit of a milestone in project terms because today the engine started and the first startup is always a special moment no matter how many times it has happened before, something to which, I'm sure, we can all relate. But leading up to that, I discovered that I had made a faux pas with wiring the ecu, in particular the two relays, fan and fuel pump. I hadn't realised that the ECU should be connected to the earth side of the relay coil not the live side. My fear was that I might have fried the ECU by putting 12 volts where it shouldn't have been but fortunately I got away with it.
Here's a short clip. The jingling sound is coming from the trumpets which aren't nipped up. I'd previously removed the backing plate for better access to the earthing point on the block.
https://www.youtube.com/watch?v=SwyY-86p_QY
HowardB
posted on 19/3/23 at 09:50 PM Reply With Quote
Sounds great! Great progress John... looking forward to seeing the 1st drive
Howard
Schrodinger
posted on 20/3/23 at 07:45 AM Reply With Quote
Well done John it's progressing nicely.
Keith
Aviemore
