<<  2    3    4    5  >>
Author: Subject: Duratec conversion - parts list confirmation
me!
posted on 19/7/12 at 08:03 PM Reply With Quote
Crumbs- I bet that goes nicely! Nice one
se7ensport
posted on 19/7/12 at 08:29 PM Reply With Quote
Standard 2.0 internals, wish I had fitted ARP conrod bolts as I could set the redline at 7500 as it stands I've put it at 7000.
Worlds shortest youtube rolling road video:
[Edited on 19/7/12 by se7ensport]
radom
posted on 19/7/12 at 08:39 PM Reply With Quote
Originally posted by se7ensport
216bhp and 170lbft at the flywheel
thats a lot
in the end which spark map did you use as a base map?
now I feel the need to dyno mine
congratulations
se7ensport
posted on 19/7/12 at 09:08 PM Reply With Quote
thats a lot
congratulations
I used the DTA 199bhp map, but it wasn't that close:
I'm happy to share mine and the target lambda which helped get the smooth power curve:
Lambda target
Lambda target
Ignition advance
Ignition advance
Note: 800 and 900 columns don't really get used, the car idles at 950rpm, anything under that with throttle load over 20% cause lots of pre-ignition so we upped the tick over in the end.
Tiger Super Six
posted on 20/7/12 at 02:21 PM Reply With Quote
216bhp from a standard engine?
Most engine builders are having to do work to get lower figures than that? My standard engine came out at 140bhp at the wheels and giving 20% drive train loss that would be around 170bhp. Most people expect a normal engine to be around 185bhp, which I believe PJ's was.
Mark
Tiger Avon
se7ensport
posted on 20/7/12 at 02:41 PM Reply With Quote
Standard internals.
Inlet, exhaust, ITBs, ECU, airbox, injectors and their location are not standard.
The figures you quote are low, 190-200 is regularly seen without internal mods.
Tiger Super Six
posted on 20/7/12 at 03:21 PM Reply With Quote
Fair enough, they're very good results, like I say most engine tuners aren't getting that without a set of cams.
[Edited on 20/7/12 by Tiger Super Six]
Mark
Tiger Avon
pjay
posted on 20/7/12 at 05:16 PM Reply With Quote
Got 192 on my Mondeo Duratec but it doesn't have the better flowing head.
Alex's is the later engine with, I assume, the better flowing head but I'm working on the basis the better head would only give another 10-15 BHP:
http://www.sbdev.co.uk/Duratec/Cylinder%20Head.htm
All a bit side tracked at the mo though with getting ready for a Fury build...
se7ensport
posted on 20/7/12 at 05:22 PM Reply With Quote
Fury build; AWESOME, a Duratec will also fit.
Mine is a 2009 Focus engine with circa 5000miles on it.
For comparison ZetecInside managed 199bhp on a Fiesta ST engine with no internal mods.
[Edited on 20/7/12 by se7ensport]
pjay
posted on 20/7/12 at 05:53 PM Reply With Quote
Cheers. Already got the engine sorted - Fiesta ST150 Duratec. It should be the first factory built Duratec chassis.
big-vee-twin
posted on 21/7/12 at 09:54 AM Reply With Quote
Its the ST150 that has the better flowing Head I understand
http://www.triangleltd.com
se7ensport
posted on 21/7/12 at 10:13 AM Reply With Quote
The high flowing head comes on the Focus from 2008, the number on the head should be RF 3S4G.
pjay
posted on 21/7/12 at 12:17 PM Reply With Quote
Definitely both ST150 and later Focuses (Foci?) have them. I suppose it's prossible they appear on other later vehicles knowing Ford.
<<  2    3    4    5  >>
