<<  1    2    3    4    5    6  >>
Author: Subject: Mx5 V6 project
clairetoo
posted on 21/5/12 at 04:01 PM Reply With Quote
Originally posted by MX5V6
following with interest Claire (MAZLOC from MX5Nutz)
Can you U2U me with the cost of a pair of those manifolds please, they look great!
I dont know if I could make another set........those were the first manifolds I have ever made , and they are now on the car so not too easy to copy
Its cuz I is blond , innit
Claire xx
Will weld for food......
MX5V6
posted on 21/5/12 at 04:31 PM Reply With Quote
do you have the dims for the manifold flanges?
clairetoo
posted on 24/5/12 at 09:49 PM Reply With Quote
All it took was a few warm dry evenings - and I now have a finished exhaust !
2" all the way to the back , then two small box's (same as on my Fury) , it just needs a small cutout in the center of the bumper
Claire xx
DIY Si
posted on 25/5/12 at 10:37 AM Reply With Quote
That's looking really good!!
Sun Tzu, The Art of War
posted on 25/5/12 at 11:04 AM Reply With Quote
It's Evolution Baby!
adithorp
posted on 25/5/12 at 11:23 AM Reply With Quote
Those look erm... NOISEY! Not sure that'll fit your image.
http://jpsc.org.uk/forum/
clairetoo
posted on 30/5/12 at 09:32 PM Reply With Quote
And this is where the noise will come out........
There has been a lot of progress over the last two (sunny ) weeks - but nearly all of it is electrics - not exactly exiting stuff , but the wiring is about 90% done (I'm just waiting on a set of plug leads and a crank sensor)
I have allso got the coil and edis mounted and wired - with all the engine wiring running through a spare hole left by deleting the air con .
Claire xx
mcerd1
posted on 31/5/12 at 01:01 PM Reply With Quote
so how much is left to do before you can fire it up ?
clairetoo
posted on 31/5/12 at 04:03 PM Reply With Quote
Not much.....I just picked up my new custom Magnacore leads , the posty has delivered my VR sensor , and I have the relays and fuse box sitting on the kitchen table
Claire xx
DIY Si
posted on 1/6/12 at 08:08 AM Reply With Quote
Claire,
How much was it to get your cam covers powder coated/painted? Thinking about doing the same for mine since I've got the heads off for some porting.
clairetoo
posted on 3/6/12 at 01:52 PM Reply With Quote
Originally posted by DIY Si
Claire,
The covers (like just about everything else on my cars....) were a DIY job - de-grease , high power alloy cleaner , and a couple of coats of Plasticoat red - then bake in the oven for a couple of hours
Claire xx
maccmike
posted on 3/6/12 at 02:39 PM Reply With Quote
I could marry you :-)
DIY Si
posted on 4/6/12 at 09:20 AM Reply With Quote
Claire,
I suspected as much!! Does Plasticoat go straight onto ally, or does it need etch priming first?
clairetoo
posted on 4/6/12 at 11:04 AM Reply With Quote
I rely on the alloy cleaner to key the surface (its the stuff you are supposed to dilute with water , but I just use it neat) . The covers on my Fury were done the same way four years ago , and the paint has stayed put !
Claire xx
clairetoo
posted on 5/6/12 at 02:54 PM Reply With Quote
After 24 hours of head scratching , and trying to get it to start - I found another page in my notes , swapped the coil connections around - and it started !
I didnt run it for long - I left the rad off to ease checking the timing - but damn it feels good to hear it after so much work
First start video - at last !
Think I may get a bit drunk tonight - at the moment I'm just sitting here with the broadest grin.......ever
Claire xx
MX5V6
posted on 5/6/12 at 02:59 PM Reply With Quote
That looks and sounds great, well done Claire!!!
DIY Si
posted on 5/6/12 at 04:53 PM Reply With Quote
Well done that woman!!
mcerd1
posted on 6/6/12 at 11:33 AM Reply With Quote
very
[Edited on 6/6/2012 by mcerd1]
posted on 6/6/12 at 12:38 PM Reply With Quote
Sounds great!
MX5V6
posted on 11/6/12 at 08:15 AM Reply With Quote
Since the post man did the business this morning and turned up laden with stainless bends and tube , I got well stuck in and made these -
I did have to pop in to work first thing to borrow a welding mask - mine packed up , and after only twenty years
Claire, who do you get your tubing from please?
clairetoo
posted on 11/6/12 at 09:47 PM Reply With Quote
Ebay............
Claire xx
MX5V6
posted on 12/6/12 at 01:24 PM Reply With Quote
Ebay............
Ta!
clairetoo
posted on 13/7/12 at 08:33 PM Reply With Quote
JD `n Coke time
Well.......I'm sat here watching the rain , with a silly grin and a large JD and coke ......... The day has finally come that I was beginning to wonder would ever happen..........................IT'S OFF THE STANDS , ON ITS OWN WHEELS , AND I DROVE OT OFF THE RAMPS UNDER ITS OWN POWER ! !
Just one slight mishap.......I forgot the servo isnt connected , so the brakes are crap - and I ran straight into some firewood piled on the drive and cracked my Racing Beat front spoiler
I have to go into work tomorrow morning , but I see a quick test drive around the block as soon as I get home
Claire xx
owelly
posted on 13/7/12 at 09:11 PM Reply With Quote
Good work Claire. It's always a nice feeling when something you've done yourself, works as it should!
http://www.ppcmag.co.uk
DIY Si
posted on 15/7/12 at 09:41 AM Reply With Quote
Well done Claire!!
<<  1    2    3    4    5    6  >>
