<<  2    3    4    5    6    7    8  >>
Author: Subject: 4.3L TVR Rover V8 into a Fisher Fury
Xtreme Kermit
posted on 7/7/12 at 06:10 PM Reply With Quote
Top job Dave. You got the bu99er out!
Do you have to take the front back off the new lump to help it fit back in?
scudderfish
posted on 7/7/12 at 06:14 PM Reply With Quote
Oh cock, I hadn't thought of that! New engine already has front cover & water pump fitted. They'll probably have to come off.
matt_gsxr
posted on 7/7/12 at 06:15 PM Reply With Quote
Well done.
Sunday is going to be busy getting the new one in.
Matt
scudderfish
posted on 7/7/12 at 06:16 PM Reply With Quote
Sunday is Wimbledon, GP, torch relay, pub and lunch with friends & family. Maybe next weekend
se7ensport
posted on 8/7/12 at 08:40 AM Reply With Quote
Remove the front shocks and possibly the rockers, I had to drop the shocks to get a Duratec in and out of my Stylus which has a near identical front end. It will make things easier and possibly not need to remove front cover and pump etc...
scudderfish
posted on 8/7/12 at 08:54 AM Reply With Quote
Yep, my plan for getting the next one in is to remove the wheels, shocks and chock the front wishbones up to drop the rockers down. Now I've had a bit of practice I think that will be sufficient to get the new one in with the front cover in place. If not, whipping the rockers off whilst dangling the engine should be quite easy.
scudderfish
posted on 21/7/12 at 03:06 PM Reply With Quote
More filth. I took the valley gasket off the old engine for a nosey and found this:-
Nice bit of wear on the cam and followers there.
So now I have to get this off that
I got the bolts out but it wasn't shifting. I thought I needed to take the starter off and discovered the most awkward bolt so far. It's an allen head and by the time I took this photo I'd already removed the sump and oil pickup
I couldn't get any swing with the allen key (5/16th inch) so I chopped about an inch off, and put it in a socket. A sort of female to female adaptor. And with a suitably long piece I got my ratchet on it. I then discovered, the bell housing is also attached by this plate here which covers the lower part of the flywheel
At this point, I got some help
So now the bellhousing is disconnected from the engine
but I haven't got them apart. I'm probably not applying enough violence....
scudderfish
posted on 22/7/12 at 04:01 PM Reply With Quote
As the song goes....
Wiggle it, just a little bit.
Xtreme Kermit
posted on 22/7/12 at 05:07 PM Reply With Quote
Woohoo!
Cam wear seems a common thing on the RV8. Wonder if they don't get enough oil after a while.
scudderfish
posted on 8/9/12 at 03:31 PM Reply With Quote
Right. Finally managed to shuffle the lumps around, but getting the gearbox on is proving to be complete arse. I'm struggling to get the input shaft correctly aligned with the clutch plate.
This is as far as I've got :-
The input shaft appears to be engaging the with the clutch as I can't turn the gearbox over anymore. However if I try to do the nuts up further, the bellhousing gets no closer and I fear I'm going to strip a thread in the block or crack the bellhousing
Bugger.
stevebubs
posted on 8/9/12 at 04:25 PM Reply With Quote
Undo the bolts and keep wiggling it...my gearbox mounted straight up to my engine first time. Second time it took nearly an hour of wiggling to get everything aligned..
DIY Si
posted on 8/9/12 at 08:57 PM Reply With Quote
If you have a helper, put the box in gear and have someone with a socket and bar wiggle the crank pulley back and forth as you try to slide the box on fully. Pulling it on with bolts is just asking to pop something.
Otherwise, it really is a case of on/off/on/off/on/off until it goes on just right.
Sun Tzu, The Art of War
scudderfish
posted on 13/9/12 at 10:49 AM Reply With Quote
Success!
A bit of wiggling up and down an it just slid straight on.
Now to put the bugger in the car......
AllWeatherDan
posted on 13/9/12 at 01:28 PM Reply With Quote
BRILLIANT!
I have been watching this with baited breath for the big unveil!!
Nearly there.....
Hurry up the suspence is killing me. :-)
Dan
There is no such thing as a stupid question.
Just the ones I ask!
scudderfish
posted on 29/10/12 at 03:06 PM Reply With Quote
And so the day began....
I got the car up on some wood so the crane legs would fit underneath it, and took the front shocks out
It starts to go in....
Cock! Is the front cover going to have to come off?
Shaking it around dodged the problem
Houston! The engine has landed!
Of course it wasn't that simple. The drivers side engine mount was a complete arse. I had real trouble getting the bolts lined up and in, so I undid the nut on the underside. Out with it came this particulary thick washer.
Whoever built my car boxed in the bottom of the engine mount so the bolt that protrudes from it is accessed through a socket sized hole in a piece of sheet. Rattling around in this boxed off section are a couple more washers and I don't have the access to get them lined up with the engine mount bolt so right now the engine isn't secure on the drivers side. I'll probably drill out the rivets and drop the sheet off, retrieve the washers and then rivet it back up.
All in all though a good day.
scudderfish
posted on 5/11/12 at 01:24 PM Reply With Quote
Well the sheet was larger than I first thought, so I just enlarged the hole enough to get the blockage out and got the washer and nut back on. All I need to do now it bolt up the gearbox mount and the propshaft and the engine will be officially fitted to the car. Then starts the plumbing and wiring...........
Xtreme Kermit
posted on 5/11/12 at 09:33 PM Reply With Quote
Good effort Dave
Back on the road for Christmas?
scudderfish
posted on 5/11/12 at 10:29 PM Reply With Quote
Originally posted by Xtreme Kermit
Good effort Dave
Definitely*
* I'm not specifying which one though....
scudderfish
posted on 3/1/13 at 12:55 PM Reply With Quote
When filling the cooling system, always remember to fit temperature sensors to the manifold BEFORE you wee antifreeze all over the garage....
MakeEverything
posted on 3/1/13 at 07:18 PM Reply With Quote
Are you planning on starting it up tomorrow? Can i come and watch??
Kindest Regards,
Richard.
scudderfish
posted on 3/1/13 at 08:10 PM Reply With Quote
Off the top of my head my to do is :-
  1. Attach prop
  2. Refit ECU
  3. Remove resistors from injectors
  4. Fit injectors
  5. Fit fuel pipes
  6. Fit oil sensors
  7. Fit temp sensors
  8. Fit new oil filter
  9. Fill with oil
  10. Prime oil pump
  11. Fit distributor
  12. Wire up starter
  13. Bleed clutch
  14. Bleed brakes
  15. Fit alternator
  16. Fit exhaust manifold
  17. Fit steering column
  18. Fit fan
  19. Fit dash
  20. Fit engine crankcase breather
[Edited on 4/1/13 by scudderfish]
Xtreme Kermit
posted on 3/1/13 at 08:50 PM Reply With Quote
So, by 3pm then
Furyous
posted on 3/1/13 at 11:10 PM Reply With Quote
Blimey! I've been going quicker than you and I've been on the other side of the world for most of the last year. We both started at about the same time.
scudderfish
posted on 4/1/13 at 10:08 AM Reply With Quote
I'm willing to bet you're more competent than me though. Everything takes me so long and motivation can be a struggle. There have been many times where I just haven't been able to face going into the garage.
Furyous
posted on 5/1/13 at 08:15 PM Reply With Quote
I'd be very worried about your car in that case. I didn't know much about engines before I started the swap but I've learnt a lot by doing it.
To be fair, when I've been back in the UK I've pretty much done nothing other than work on the car. Fingers crossed, it's tomorrow for me. Still lots to polish off once the engine's going, though.
<<  2    3    4    5    6    7    8  >>
